RRM Rear Anti Sway Bar Install
Old Sep 29, 2004 | 07:34 PM
ralliartracer's Avatar
If anyone could help me out with the installation of the rear sway bar id much appreciate it. I looked under there myself and it looks pretty much like a bolt on job, but i wanna know if it will mess anything up (like alignment for example) before i start undoing things.
Old Sep 29, 2004 | 09:21 PM
otter's Avatar
EvoM Administrator
Nope, it will not affect your alignment or anything like that. It's just as simple of a bolt on job as it looks. Just make sure you take a good look at it before you take it off so you know where everything goes when you put it back together.
Old Sep 29, 2004 | 10:30 PM
captain150's Avatar
Do you have a torque wrench? Be damn sure you have the bolts to the proper spec. People don't give torque specs any respect, they are there for a reason.
Old Sep 30, 2004 | 09:59 AM
Myszkewicz's Avatar
Torquing EVERY bolt to spec is way overkill. The only things I break out the torque wrench for are the head bolts and lug nuts. Everything else gets tightened until it won't fall off, but not so tight that the bolt breaks off. It's a system that's worked well for me for the last 20 years or so, ever since I picked up a wrench.
Old Sep 30, 2004 | 12:50 PM
captain150's Avatar
I like to be safe. What does it hurt to torque the bolts properly? They are your suspension parts...
Old Sep 30, 2004 | 02:08 PM
Myszkewicz's Avatar
I guess it doesn't hurt, but it does take more time, if you can even find a spec for every bolt.
The only thing that's ever fallen off my car was one of the wheels, when the monkey at the tire store didn't torque the lugs. The LF wheel came off while I was on the Interstate, doing about 65-70.
Any time you have anything done where a shop has to take off your wheels, re-torque the lugs yourself when you get the car back. Don't learn this lesson the hard way.
Old Sep 30, 2004 | 02:22 PM
otter's Avatar
EvoM Administrator
It's not necessary to torque the sway bar. Tighten the endlinks until the bushing is firmly in there (but don't crush it) and tighten the two brackets enough to hold the bar firmly w/o breaking the bolt. It'll be fine.
Old Sep 30, 2004 | 02:43 PM
captain150's Avatar
Mmmkoy, I suppose the sway bar is not a big deal since the car won't crash if it comes loose. But something important, I would always torque. Like the wheels, strut mounting, tie rod ends. Anything that would be DISASTEROUS if it came loose.
Old Sep 30, 2004 | 06:43 PM
i dont have a torque wrench. . . will a torque wrench give me more torque? can i get a horsepower wrench too?? how do they work? im really excited about this!
Old Sep 30, 2004 | 06:54 PM
captain150's Avatar
Are you serious? Or just mocking me?
Old Sep 30, 2004 | 07:01 PM
???Am i confused about what a torque wrench is???
Old Sep 30, 2004 | 07:09 PM
pocoRA's Avatar
A torque wrench is an adjustable wrench, if you need to torque a bolt to 40LBS, then you set the wrench to 40 pounds and tighten the bolt till the wrench starts clicking and not turning the bolt. There are different kinds as well, but they all do the same thing.
Old Sep 30, 2004 | 07:59 PM
captain150's Avatar
Adjustable wrench for tightening bolts. It is required for some car repairs (any time you take the head off, you NEED a torque wrench).
Old Sep 30, 2004 | 08:02 PM
i know, i work at a mechanic shop. thanks guys.
Old Oct 1, 2004 | 01:47 PM
otter's Avatar
EvoM Administrator
Ya'll crack me up.
LuckyLancer
Dec 4, 2016 05:32 PM
mitsuatb
15
Aug 10, 2016 06:37 AM
w2pac12345
23
Apr 11, 2009 10:46 AM
Happy Madison
Jan 24, 2006 01:06 PM
MVEOVA
Nov 23, 2002 09:41 AM
