Auto-X Tire pressure
But it really depends on the driver. It is too hard to judge otherwise. Just try a ton of different setups and see what works for many courses. Then you can adjust from baseline to match each condition.
When it was 45 degrees out, and in the stock yoko's, I ran 38 rear 37 front. I won pax that day. When it was 80 with the sun shining, and my tire gauge was giving me bad readings, I ran that same pressure with direzza's and was sucking it up big time. Then I tried another tire gauge, bumped it up to 48 rear, 46 front, and picked up two seconds from my best run.
That's not to give you any frame of reference as much as it is to give you an idea of how much the right pressure can vary. I prefer not to be below 44 psi in the summer though, too much tire roll.
TougeTuned00
Aug 28, 2008 02:04 PM
TougeTuned00
May 1, 2008 08:34 AM
Ride_59
10
May 26, 2006 09:36 PM
