Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Hubcentric Rings?
Old Oct 1, 2009 | 07:03 AM
ugakirk's Avatar
Hubcentric Rings?
I think I am going to be ordering some Advan RS's today and I wanted to know if you need the hub centric rings to fit 19x10's +25? Does anyone know?
Old Oct 1, 2009 | 07:06 AM
lancer0220's Avatar
well you need to know the diameter of the wheel bore and the diameter of the hub. if they are not the same which most likely they arent you should get hub rings. i know the lancer is 67.1 not sure bout the evo x.
Old Oct 1, 2009 | 07:57 AM
ugakirk's Avatar
Okay thanks. I just know alot of people on here are running 19" Advans and was just wondering if everyone had them.
Old Oct 1, 2009 | 08:26 AM
LaXGSR's Avatar
The evo x is 67.1 mm, and many after market wheels are 73 mm. You'd need to find out the bore of the advans you want to determine if you need hub centric rings. If it's not 67.1, then you do. I'd recommend the plastic ones that don't corrode and get stuck on the hub like the metal ones can.
Old Oct 1, 2009 | 10:27 AM
wongck's Avatar
you don't need it but its recommended. You need a 73mm OD with 67.1mm ID hub ring, $10 on ebay.
Old Oct 2, 2009 | 09:44 AM
Touge Factory's Avatar
As mentioned by others...
Not needed but recommended.
We have blue anodized aluminum rings in stock.
67.1mm / 73mm
Old Oct 3, 2009 | 12:53 PM
smoke90's Avatar
Yes you need them.
I had a strong discussion here with a vendor.
And If you do not want to have the steering slighly shaking at high speed you need them.
Old Oct 4, 2009 | 10:28 AM
seven_227's Avatar
I'd put them on since there is nothing to lose, except the $30 they'd cost you.
Old Oct 5, 2009 | 08:09 AM
LaXGSR's Avatar
Like others have said, get them. I tried running a day without hub rings and the vibration above 80 mph was so bad it felt like the steering wheel was going to fall off. I even tried progressively torquing the lug nuts as some have suggested to help center the wheel, but the vibration was still there. Get some plastic hub rings from Discount Tire for $20.
Old Oct 20, 2009 | 08:46 AM
lancer0220's Avatar
get th em on ebay for 10.00 shipped got them in 7 days.
this is the seller
http://myworld.ebay.com/ebaymotors/importsplanet/
search for mitsubishi, lancer 67.1 or just lancer hubcentric rings
Old Apr 19, 2010 | 08:55 AM
Gardo_Segovia's Avatar
Originally Posted by smoke90
Yes you need them.
this.
Tried to pass someone on the freeway, so I had to accelerate at 80mph and I felt the shaking. Keeping my speed to 65-70 until TF ships the aluminum rings.
Old Apr 19, 2010 | 03:25 PM
slo4g63's Avatar
+1 Support a local vendor and order them from TF up above, they shipped mine out right away.
Old Apr 19, 2010 | 03:46 PM
heavyD's Avatar
Plastic rings aren't so good if you are tracking the car as they can get soft under extreme heat from hard braking.
Old Apr 19, 2010 | 04:26 PM
LaXGSR's Avatar
Good point, but I haven't personally had issues with my plastic hub rings. Done about 4 track days on them, but I limited sessions to 10-15 minutes each to not abuse the car too bad The purpose of the hub rings is to center the wheel onto the hub before tightening the lugs. It doesn't really do anything once the wheel lugs have been tightened, so it seems that as long as the plastic doesn't actually melt or crack, it shouldn't have any negative effects.
Old Apr 19, 2010 | 04:48 PM
Overnight shipping costs me more than the advertised 'shipped' price by TF. I need it shipped overnight, my mistake for the lack of planning.
It should be on my doorstep tomorrow
