Eibach Multi-Pro R2 w/ Vorshlag Plates
I'm testing a self made heat shield to prevent wet weather from soaking the wrap on my headers so much, so far so good. Basically you can use the two mounting bolts for the center of the strut tower brace to get a heat shield in between the manifold and reservoirs if needed. I'm sure the normal underhood heat isn't that big a deal but if it was constant radiant heat off the manifold it would somewhat defeat the idea of having a remote reservoir shock where the additional fluid is supposed to take the heat better and keep the shocks working at or near peak ability.
For a smooth road course it might not be that big of a deal, but rough road use or off-road it might make a difference. Here is an snip from http://www.fourwheeler.com/techartic...cks/index.html
Shock absorbers control unwanted motion through a process commonly called dampening (hence, their alias "dampeners"). They turn the kinetic energy of suspension movement into heat energy, which is then dissipated through the shock body. Without shocks, your rig's springs would bounce up and down after hitting a bump (taking your rig with them) until all of the energy put into the springs by the bump was used up. So a shock's job sounds simple, right?
Well, here's the thing. While fine for street use, a standard monotube or twin-tube shock has drawbacks. The biggest disadvantage is that when asked to endure sustained rough terrain, they can overheat. This is called aeration, and it's what takes place when the oil in the shock foams due to the heat generated by the shock, turning the previously mentioned kinetic energy of suspension movement into heat energy. The result is that the shock loses its ability to dampen. This allows that crazy spring motion to run unabated. This not only creates a bouncy ride but also scary handling.
Remote-reservoir shocks can help solve this problem. They're designed with an external reservoir that increases fluid capacity. This increase in capacity helps lower fluid temperature, thus offering the ability to blast over rough terrain without experiencing shock fade due to overheating.
For a coilover, the Vorshlag plates have a lower stack height than stock and thus give you more bump travel at a given ride height. They would lower your car if you didn't touch your height adjustment. This is with their integrated upper spring perch and bearing.
Awesome plates.
- Andrew
Awesome plates.
- Andrew
Quick question... how high up the strut body do you have the collars set at for the rear? I have a set of R1s that I installed last night and I'm almost all the way to the top and the car is "slammed." It is bad and something has to be wrong.
Looking at your pictures I'm wondering if Eibach forgot to send me the two rubber bushings when they shipped them. I see the rubber bushings in your pics for the rear. Did those replace the rubber doughnuts that go in the stock rear tophat? Tried calling Eibach but they're closed till the 4th.
GTWorx maybe you could chime in??
Thanks
Thanks
Awesome plates.
- Andrew
Awesome plates.
- Andrew
Thanks
Thanks
mine are the same, i still have about a half an inch to an inch adjustment left on the top in the rear. they are almost all the way at the top. i thought it was weird but went with it since it was still clearing the wheel/tire. all the bushings did get replaced on the tophat for the rears.
- Andrew
