Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Evo X Motion Ratios ?
Old Feb 7, 2010 | 08:14 AM
Protege's Avatar
Anyone here knows the Evo X suspensions motion ratios ?
Old Feb 8, 2010 | 06:39 AM
DaveGSR's Avatar
I've been waiting for the same info, too. Not sure EvoM has that level of knowledge about the X yet.
Old Feb 8, 2010 | 05:58 PM
Protege's Avatar
Hi DaveGSR, I'm pretty sure there is.
Even if its not from fellow enthusiast, I'm pretty sure (suspension) vendors/dealers already has this information.
Crossing my fingers that they will notice this post
Old Feb 8, 2010 | 06:47 PM
Hiboost's Avatar
http://stockcarproducts.com/pstech9.htm
Start measuring and get back to us... haha
Old Feb 9, 2010 | 08:21 AM
Protege's Avatar
honestly, I'm reaaaaally trying to avoid that !!
Old Jun 27, 2011 | 09:16 AM
Iowa999's Avatar
bump
Has anyone measured the Evo X suspension in detail. If so, would you be willing to share? Motion ratios would be very useful, please.
Old Jun 27, 2011 | 10:52 AM
Iowa999's Avatar
After another hour spend on the intertubes, I found .96 front and .84 rear for the Evo X. I'd still appreciate confirmation, though.
Edit: moving on to Step Two, anyone know the unsprung weights for a stock Evo X? (With or without wheels-and-tires is fine, thanks, just tell me which it is.)
Old Jun 27, 2011 | 01:15 PM
GTWORX.com's Avatar
I'm not in the office, but .84-ish sounds about right from memory. The rear shock is out there a bit towards the hub.
Which is partially why we aren't quite as aggressive with the rear spring rate on this chassis in comparison to the old one.
- Andrew
Old Jun 27, 2011 | 02:24 PM
Iowa999's Avatar
Thanks. I even saw you in the thread that was most definitive ... the rear lower mount is 36 cm out on a 43 cm arm. For front McPs, most people just use .96 as a default. For now, I will, too.
bracer
Feb 8, 2020 01:56 PM
motion3131
Northwest Region
30
Sep 25, 2011 10:33 AM
nudge120
Feb 23, 2011 08:01 AM
burt_reynolds
Feb 17, 2009 03:39 PM
evo8dad
Jun 27, 2007 08:05 AM
