The Brake Rotor, Pad, Line, Fluid, and Duct Thread (Evo X)
So I tried putting EVO VIII ducts on an EVO X. The mounting bolts are larger diameter on the EVO X, and the spacing a little different. BUT - drilling the mounting holes out larger made them work. So although not perfect - they seem to work!
So this is an option for the EVO X guys to look at.
Some photos of the test fitting.
I was wondering if someone could answer a few questions. I have an Evo X MR and will likely have to change the brakes soon. What options (companies) do I have for the front two-piece rotors? Does just the rotor piece get replaced? I am unfamiliar with this type of design. Also, I'm assuming I can use a standard one piece rotor in the back?
I don't track the car and use mainly for DD and spirited driving. Any suggestions for rotor/pad combo that is of good quality and cost effective?
Chris
Hi, i am looking into upgrading my brake lines to SS line for track, DD and spirited driving. I would like to know if drving in freezing temp. would be an issue since it is also my DD in the winter. Does anyone have it on their car as DD and live in extreme cold winter area? Thx
Chris
I looked around some vendors' website and only two companies advertised their product as DOT approved and that's Harmon Motive and WORKS.. I was wondering if other products such as AMS, goodridge and techna-fit are just as good and meet all safety standards?
In case you didn't get this reading, braided lines will wear out, just different than rubber. The braiding allows tiny bits of dirt/crap to actually rub and wear the rubber that the braiding holds tight. The plastic sheathing design is to minimize that, and maximize the SS lines lifetime. But it's not permanent. I've never had problems with 20 years on rubber lines, so I'll just put another $100 on the 7 year maintenance cost plan
breakdown.
Get fluid (Prestone DOT4 is a great/cheap DD fluid) and flush system.
If my AMS brand blows apart, not only am I damaged, but they'd be out of business FAST -- they live (or die) on their reputation with the tuner aftermarket performance crowd. They fit great, they're covered with a sheath.
breakdown.
breakdown.
