Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
steering wheel vibration and low offset wheel
Old Jun 7, 2010 | 05:01 PM
raytrix's Avatar
Originally Posted by Quang-Star*
i heard the whiteline roll center causes dramatic vibrations in the cabin?
is that a question or a confirmed fact?
Old Jun 7, 2010 | 07:40 PM
Quang-Star*'s Avatar
well, im doing my research on getting that roll center kit as well.. spoke to a couple hardcore track guys.. they said its pretty much for the track since it cause noticeable vibrations in the cabin.
i posed what i said in a question form b/c you have it. I thought u may be able to confirm it?
Old Jun 7, 2010 | 08:38 PM
raytrix's Avatar
vibration in my case is pretty much at the steering wheel not the entire cabin.
Old Jun 8, 2010 | 02:21 AM
love67's Avatar
is it possible that the rotor bent? and costing the vibration?? because i heard the brake pad is rubbing the rotor, and it doesn't sound "the normal rubbing sound"...
also i checked... my driver side rotor is not really really flat out with my rim...because when i installing my wheel on the driver side, it seems there is room for moving around...and same happen with my oem's wheel too...so it should not my rims problem?
oh...also i feel it also vibration in the cabin, not just the steering wheel, but this happened after my track day tho...
Old Jun 8, 2010 | 05:36 AM
raytrix's Avatar
I just put the stockers back on and drove to work. No vibration at all even at speeds of 87 mph. Solid as a rock. So I'm assuming it's 2 for 2 from the same shop that didn't balance my wheels correctly. I'm going to take them to a tuner shop that sells aftermarket rims and tires. Or I might need to buy a new set of hubcentric rings that is a tighter fit.
Old Jun 8, 2010 | 07:21 PM
awesome! im not running hubcentric and im not experiencing any issues...
What do you think about the Roll Center kit? do u notice any difference?
Old Jun 19, 2010 | 04:23 PM
sailorcor's Avatar
IF you have aftermarket wheels you need hub centric rings for your specific rim setup/size. That will get rid of your vibration problems you notice after putting new wheels on. Also, you should always get road force balancing, so so so much smoother and def worth the extra $$$
Old Jun 19, 2010 | 04:39 PM
jimm's Avatar
The "vibration" in the cabin with the whiteline kit alone is rubish. I have the kit and have no vibration. I also have 20mm Kics spacers with MR BBS wheels....also no vibration.
I did have Robi install it so maybe there is a trick to installing them correctly.
PaulyX
20
Mar 4, 2018 07:04 AM
g7igo7
12
May 11, 2016 08:33 AM
Bad Vibe
Lancer Troubleshooting
25
Nov 18, 2008 11:57 PM
hgby
Sep 30, 2008 09:03 PM
deegaw11
May 13, 2007 07:06 PM
