Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Reduced Braking In Wet?
Old Jan 28, 2011 | 04:40 PM
wicked white14's Avatar
All,
When I am driving down the mountain and it is super wet I sometimes have reduced braking power.???? It happens when super wet and haven't used brakes in many miles.....the pedal is still firm it just seems like it is a delayed reaction......scared the sh*t out of me!!!! Is this due to the large surface areas of the rotors????? Any input appreciated!!!!
AA
Old Jan 28, 2011 | 04:57 PM
Bighec's Avatar
Did they lock up? Or did you hydroplane?
Old Jan 28, 2011 | 05:21 PM
Tuxevo's Avatar
No, it's due to the water. It's reducing the friction generated by the contact patch of your tires and momentarily reducing the I initial bite of your brake pads.
Old Jan 28, 2011 | 05:23 PM
Hiboost's Avatar
In the winter months with my 3" brake ducts blowing cold, wet air onto my brakes I really need to be carefull of reduced braking power. Cold wet brakes just won't have a very good initial bite, so whenever you anticipate needing the brakes in such weather, be sure to ride them for a few seconds to make sure they are there. Worst case they should be at near full power after a few seconds with some extra pedal pressure, but sometimes those first few seconds are critical to safely get out of trouble. The sportscar compound lkely doesn't help matters, and I'm sure some pad combos work better than others in the wet.
Old Jan 28, 2011 | 05:46 PM
Thanks guys....That is what i was thinking but just wanted to be sure. If you're not anticipating it it can be pretty freaky!!
Old Jan 28, 2011 | 05:53 PM
Tuxevo's Avatar
Double post.
Old Feb 1, 2011 | 07:08 PM
lancerarmstrong's Avatar
Originally Posted by wicked white14
All,
AA
you answered your own question in the title of your own post
Old Feb 1, 2011 | 07:28 PM
spdracerut's Avatar
Another thing to consider is just the type of pad you're running. Way back in the day, I had Porterfield R4S pads on my car and I was driving up to Michigan from Texas. Being May, it was 90s in Texas but 30s in Michigan. I took the off-ramp from the highway, got on the brakes and nothing.... I barely got stopped in time! So just plain ole cold weather can be an issue depending on the pads you're running.
Girodisc Martin
EvoX 'For Sale' Suspension / Brakes / Handling
233
Feb 25, 2017 09:31 AM
Girodisc Martin
Evo 'For Sale' Suspension / Brakes / Handling
415
Aug 2, 2016 08:45 PM
cts4g63
Jan 6, 2016 02:22 PM
Robevo RS
Jul 13, 2011 02:59 PM
sponge bob
Apr 18, 2006 07:41 PM
