springs and sway bar
this time I am more than ready to make the move for suspension upgrade
I already removed the rear sawy bar and the front sway bar is nearly removed.
I realized how difficult it is to take it out. I have order an hydraulic jack and that should do it
As far as choice I am ready to go with Springs and no coil over (just budget as I have so much to do on the cars)
Springs are only $300 and apparentely a good set of coil over is more lie $1600 to $1800
I am not looking to have the car to look better. not interested in a drop as with the 275 on 18 x 10.5 I am concerned it will rub
Just interested to road racing as I rarely use the car on the street and everything has been removed inside the car.
So the choice is Swift Spec R with hotchkis sway bar
I am plannin to order this week.
Is there a better choice for road racing?
I have the swift spec-r with hotchkis sways, but if it is a track car only, I would defintely upgrade to coilovers for sure. Yes it will rub also, mine rubs with my 9.5 wheel, I needed a fender roll, the process was $100, and took a little over an hour.
It handles very good with my current setup, amazingly actually. However, I do plan to upgrade to coilovers next spring, and if its a track car you'll be able to take full advantage of adjustablility and dialing in the perfect setup for your car.
but it is the truth
also as I am using the car on the snow the coil over will do a better job
thanks
Don't remember but I will say somewhere around 25mm.
with the same diameter you could have different strenght as you have to take into account the steel they use and if it is hollow or not and the inside diameter.
So basically it is not only diameter.
I order a hydraulic transmission jack to support the sub frame from underneath
The_X_Effect
43
Jan 17, 2017 07:27 PM
DeweyD
Jan 21, 2015 09:12 AM
trinydex
23
Sep 17, 2009 12:44 PM
Galant VR-4 #34
Automotosports - Illinois
Jan 18, 2009 05:51 PM
