Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
18X9.5 rOTA GRID
Old Nov 4, 2011 | 03:18 PM
lookitznite's Avatar
18X9.5 rOTA GRID
I just purchased 265/35 tires, I was thinking to get the ROta Grid +20 I was wondering if anyone has the same setup if it worked? Im glad I didnt purchased the rim just yet. Does anyone happen to know if itll fit?
Old Nov 4, 2011 | 03:26 PM
J Dog's Avatar
Check my sig...they fit. Sitting on same springs as you.
Old Nov 5, 2011 | 12:12 AM
Wow running 275? So I don't have to roll if I run 265/35?
Old Nov 6, 2011 | 08:52 PM
Fractur3's Avatar
Not trying to be a dick, but this information is ALL over the board, a simple search would have found you the answer to this question.
The tire will fit perfectly on the Rota, if you are on stock suspension you'll be fine, if you're lowered you'll need to roll the rears.
Old Nov 7, 2011 | 04:10 PM
J Dog's Avatar
^ Like he said you'll rub lowered so to be safe you'll need the rears rolled. Cost me 75 bux to have mine done. You'll probably rub on the front too with the plastic liner but I just let the tire rub it down to wear it doesn't rub anymore. Other people have used heat guns to mold it out so it wouldn't rub.
Old Nov 12, 2011 | 08:37 AM
Haha thanks, we both also bought the same tires! Do u have any pic of your car? Does it look aggressive at all?
Old Nov 12, 2011 | 09:26 AM
menasor's Avatar
You're going to rub on the rear. I'm sitting on Swift Sport Machs which are a little higher than Eibach Pro Kits and they rub with someone sitting in the rear and going over a big bump. Definitely looks aggressive though. The wheels will sit flush with your fenders. It's the perfect fit imo.
Old Nov 12, 2011 | 09:37 AM
Sufu's Avatar
I have these wheels on 265/35/18 tires, but I am not lowered so I only rub on lock to lock. You might need to roll fenders if you are lowered.
Old Nov 12, 2011 | 09:48 AM
menasor's Avatar
Hm I actually don't rub lock to lock running on 265/35/18 Ventus V12
Old Nov 15, 2011 | 06:34 PM
Jubey97's Avatar
post some pics!
Allentotora
May 24, 2017 07:59 AM
poon'dEVO
Sep 25, 2014 10:18 AM
thisonecountz
10
Apr 25, 2014 12:11 PM
03mitsevo
For Sale - Wheels / Tires
11
Aug 5, 2013 08:57 AM
Rocky_RA
Sep 15, 2010 08:50 PM
