18x9.5 tire size ??
#31
im actually running a 265 hankook v12. still has a slight stretch but ive seen similar sizes had a more full look. anyone know which brands tend to run bigger? im looking for more protection for my wheels
#32
In the same boat.
Got some 18x9.5 volks ce28n on order and trying to decide which tires to go with.
Either 265/35 Hankooks v12s or Nitto Invos. Leaning more towards the v12s since the dollar to performance ratio can't be beat.
#33
http://www.tirerack.com/tires/survey...=true&filter=y
#34
My bad clearly it shows i havent throughly done my research. From what i read so far the hankooks v12s are quite popular.
But i think i've settled on a tire. Pilot super sports. Figure im already spending so much on rims can't cheap out on tires either. Must get something decent.
#35
OP never mentioned the offset. I have recently put on 9.5's with 22mm offset. This seems to be about the perfect offset for the 9.5. I have Direzza ZII's in 275/35-18, and it slightly rubs the inner fenders at full lock in front. It also rubs, but does not cut the rear fenders in extreme manoevers. Any more offset either way would make either nuisance a problem. As is, I can live with both easily. Suspension and alignment are stock.
#36
When pushing it, as you are with 275s, the other option is to get long studs for the front hubs and run a spacer in the front (only). That way you can have mismatched offsets and still rotate the tires.
And, please, I beg you (all): don't say anything silly about mismatching offsets on an AWD. It's fine.
turbo50mike
44
Jan 17, 2017 07:06 PM
FS[MidWest]: Chicago: F/S 18x9.5 NT03's with tires
evowner17
For Sale - Wheels / Tires
21
Dec 29, 2014 09:12 AM
Hakmeister
Aug 25, 2012 05:38 AM
SinCityEvo9
10
Mar 23, 2012 05:32 PM
