Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
20mm Spacers Cheap..
Old Dec 29, 2011 | 04:29 PM
BOOSTED2010's Avatar
Would you guys buy these?
http://www.ebay.com/itm/20mm-Wheel-S...item43ac0c6eea
Old Dec 29, 2011 | 07:04 PM
userwave's Avatar
I would spend the extra on a known name like H&R
Old Dec 30, 2011 | 11:12 AM
tlsole's Avatar
last thing you want is a stud to break..
Old Jan 14, 2012 | 10:06 PM
rich250x's Avatar
I wouldn't feel comfortable driving around in these, i'd save up for a set from a reputable brand
Old Jan 15, 2012 | 05:30 PM
black95tt's Avatar
I don't see how they are any different than name brand. Grade 8 hardware and machined aluminum? What could go wrong? I bet they would be fine. I'll pick up a set and let you know!
Old Jan 16, 2012 | 04:18 PM
turbodsm15's Avatar
ebay brands are not always bad, i would be more worried for more mechanical parts. but for spacers they should be fine.
Old Jan 16, 2012 | 04:45 PM
Vivid Racing's Avatar
No. I would not buy those. The reason being, they have no hubcentric rings. Without hubcentric rings, you can end up vibration at/around 70mph.
If you want a good price on some spacers that DO have hubcentric rings, let me know. I always recommend H&R.
Old Jan 16, 2012 | 04:49 PM
evo8dreamcar's Avatar
I have a set of eBay 20mm spacers hubcentric, ride fine, and No problems. Good quality
56$ for two
Old Jan 16, 2012 | 04:51 PM
turbodsm15's Avatar
i take back my previous statement. hubcentric is probably necessary.
Old Jan 17, 2012 | 04:21 PM
56$ for two
Hubcentric is the difference between what you have and what the OP was asking about. Personally, I wouldn't gamble with eBay spacers just because even the slightest issue can cause vibrations. There are cheaper alternatives to the H&Rs, though. Ichiba spacers are pretty good.
Old Jan 17, 2012 | 06:24 PM
Iowa999's Avatar
Normally all you do is spam tech threads, but this time you said something very useful. Thanks.
Oops. Spoke too soon.
Old Jan 17, 2012 | 09:54 PM
Gqracer's Avatar
Reputable brand or not, if the studs are not ARP, its junk.
Old Jan 18, 2012 | 05:54 AM
black95tt's Avatar
Ok.
Old Jan 18, 2012 | 07:35 AM
Kracka's Avatar
Just because they claim Grade 8 doesn't mean they actually are. A Chinese eBay company lying...OMG no way! [gasp!]
Old Jan 18, 2012 | 08:37 AM
black95tt's Avatar
Grade 8 isn't some holy grail. It isn't crazy to think that they very well could be grade 8. They are only marginally more expensive than low carbon steel anyways. It could easily be verified by a simple hardness test.
Just for reference, A grade 2 1/2" fine threaded bolt will hold 10,000 pounds tensile before breaking. A grade 8 will hold 24,000lbs. Under normal conditions (stock studs torqued to 85 lbft) you have about 10k lbs of clamping force per lug. Assuming these weren't grade 8, but grade 5 which is similar to the stock lug, you'd have at least 50k lbs of clamping force total. I think that would suffice for DD and some spirited driving....it is good enough for OEM.
The cost of spacers is about as ridiculous as what people charge for an upper intercooler pipe. This is what they should cost realistically.
I do agree about the hubcentric rings though. Those would definitely be necessary.
Luckystryke
For Sale - Wheels / Tires
Aug 8, 2016 06:34 AM
HaterMagnet
11
May 24, 2016 01:17 PM
CodyJamesBitxh
Mar 8, 2016 06:02 PM
quickflips
For Sale - Wheels / Tires / Suspension / Brakes
Nov 6, 2011 08:46 AM
GsrEviluTionX
Dec 9, 2010 02:14 PM
