Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Steel spacers
Old May 13, 2016 | 11:21 AM
HaterMagnet's Avatar
Steel spacers
Anyone know where i can get steel spacers for my x? i wan hub centric and 20-25mm spacers. link?
Old May 13, 2016 | 11:38 AM
LetsGetThisDone's Avatar
http://www.motorsport-tech.com/
And get ARP wheel studs.
Get aluminum. Steel is heavy, don't need it..
Old May 15, 2016 | 08:30 AM
g7igo7's Avatar
Check out ISC spacers. They make great ones for subarus for sure.
Old May 24, 2016 | 05:37 AM
ChrisB's Avatar
Veteran: Air Force
Ichiba V2s are the way to go.
https://www.autocityimports.com/2008...i-p-13911.html
Old May 24, 2016 | 07:29 AM
RazorLab's Avatar
25mm steel spacers would be like putting boat anchors on the each side of the car.
Old May 24, 2016 | 07:55 AM
Originally Posted by ChrisB
So you can have their POS wheel studs fail? No thanks...
Old May 24, 2016 | 09:38 AM
ChrisB's Avatar
Veteran: Air Force
I've had them on my car for 2+ years with no issues. I don't know what the circumstances surrounding your car are, but it looks like you tracked with them on? I wouldn't advise tracking any car with spacers.
Old May 24, 2016 | 10:10 AM
You can track a car with spacers just fine. Just need parts that aren't pieces of **** yet are being sold as quality parts. Car now has ARP wheel studs and custom billet 6061 spacers. Looking forward to no more issues as this is a tried and trued setup.
Old May 24, 2016 | 11:07 AM
WarmMilk's Avatar
I'd only track on wheel spacers if the car has longer studs and the kinda wheel spacers that pass through the stud. I'd never track a car with spacers that bolt to the hub and then have their own studs
Old May 24, 2016 | 11:33 AM
That's what I had, from Ichiba. An extended stud and slip on spacer "kit". They all sheared off right at the base of threads. I was not using bolt on spacers.
Old May 24, 2016 | 12:04 PM
WarmMilk's Avatar
sorry, I should have said with quality studs... so basically arp, I don't really know of any other brands that make quality studs and they're not expensive enough to gamble on anything else
Old May 24, 2016 | 01:17 PM
Yes I learned my lesson. And will continue to tell people. Even on your daily, if you're going to run spacers its not worth saving $100 to risk thousands of dollars in body work.
alby988
May 22, 2007 05:15 AM
SMrider102
Apr 11, 2005 05:53 PM
Mean TT
Oct 13, 2004 02:56 PM
4-BNGR
Oct 23, 2003 06:03 PM
