Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
How to install Eibach Rear Sway bar with stock Endlink
Old Jan 16, 2012, 05:07 PM
turbodsm15's Avatar
good write up.
Old Jan 16, 2012, 08:06 PM
ak47m203's Avatar
Originally Posted by Iowa999
Because how much a wheel droops when unloaded is not a good indicator of where it will be when the car is on the ground. The goal is to have no pre-load at static ride height, not to avoid pre-load at full droop.
FLK agreed with you but he wanted somebody is sitting on the driver side. lol.
Old Jan 17, 2012, 10:05 AM
Iowa999's Avatar
You might laugh, but I used to take three huge water bottles with me when I went for an alignment in the DSM.
Old Jan 19, 2012, 01:15 PM
an2ny's Avatar
My stock end-links look different. I think that they have an allen bolt on them…
Old Mar 6, 2013, 07:20 AM
dasmikechen's Avatar
Trying to help others out there, I contacted the manufacturer of my rear sway bar and adjustable endlinks asking how to avoid pre-load when installing. They said:
"The car must be level and at ride height first. Then you adjust the link till it will go in with no force and that way there is no pre load in straight line."
So what I think this would mean to other users is if you are planning to use the stock end-links, you better hope they line up to exactly the holes you want on your RSB or you will be putting preload on them no matter whether you tighten before or after on the ground.
hood.philosophy
Evo X Dyno Results
Jul 17, 2016 12:44 PM
Czarcasm
Mar 27, 2013 04:58 AM
ak47m203
North Texas Evo Club (NTEC)
40
Dec 20, 2012 08:28 AM
Tekniq
Jul 17, 2012 08:10 AM
evodave
35
Oct 5, 2009 08:10 PM
Quick Reply: How to install Eibach Rear Sway bar with stock Endlink
