Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Eibach pro kit question
Old Jan 26, 2012 | 08:04 AM
Kracka's Avatar
You guys are funny.
Eibach obviously knows nothing about suspension, just a bunch of monkeys coiling wire... To each their own
Old Jan 26, 2012 | 09:03 AM
Iowa999's Avatar
(That was a pathetic response, especially for a moderator.)
Please note that I was criticizing ProKits on KYBs, mostly because KYBs are highly progressive. Bilsteins, in contrast, are highly digressive, which works perfectly with highly progressive springs. If Eibach put a lot of thought into the design of their ProKits for Evo Xs, then they might have based them on the MR's shocks, instead of the GSR's shocks.
edit: this is a bit OT, but my parenthetical sort of requires it. You were quite correct, Kracka, to slap me for my initial eBay comment, but not for the reason you gave. I completely disagree that direct experience is a requirement to comment. An understanding of these system coupled with accurate data for the item in question is at least as good, if not better. My mistake was assuming that Eibach designed the ProKit for Evo Xs to be the same as that for 2G DSM. The mistake was not checking, first. Once it was clear to me that ProKits for Evos Xs are highly progressive, in contrast to those for 2G DSMs, I realized that what I wrote was way of base and accepted the slap (silently). But as soon as contrary experience with ProKits was posted, I started thinking about why and then wrote what I did this morning. If you think that your role as a moderator is to deride deeper discussion than "dooood, those blue wheels are wicked!" then have at it, but you'll never get the signal-to-noise ratio of this site up that way. Encouraging deeper discussion and understanding would be my suggestion. That's how we do it on DSMTuners. cheers
Old Jan 28, 2012 | 06:37 AM
Alpha X's Avatar
I have Eibach Pro springs and absolutely love them! The drop is perfect and have no complaints as of yet.
Old Jan 30, 2012 | 03:29 PM
tlsole's Avatar
I have eibachs and love them, great for daily driving. I dont really track my car and the drop is nice. Like kracka said, buy stuff that suits you.. for me, eibachs are just fine. I'll probably look into a set of coilovers eventually though..
Old Feb 4, 2012 | 09:51 PM
daspasian's Avatar
@ Kracka -- true.
Old Feb 29, 2012 | 02:12 AM
Bigstakk's Avatar
Originally Posted by AFD
Just wondering, what springs would you recommend for a modest drop, similar to the ProKits, for a daily driver.. preferably something that would be about equal to or slightly better than stock?
If you are looking for a modest drop than the pro kit is the opposite of what you are looking for FYI...have'm on my car and the dang thing is slammed...after fully settling (12Kmi later) it seems like the front is lowered closer to 1.5-1.7 and rear ~1.3-1.4in drop...much less body roll though...
Old Feb 29, 2012 | 10:01 AM
AFD's Avatar
AFD
Yeah, after looking at some pics, I'm thinking the ProKits might be more drop than I'm looking for.. thanks for the feedback!
Old Feb 29, 2012 | 10:11 AM
margie's Avatar
I didnt cut the bumpstops Should i be looking into that? Other than that i love the stance and they ride just fine to me. I thought i was going to worry about scraping on parking garages, bumps, driveways, and so on and i have no problems
Old Feb 29, 2012 | 11:15 AM
Sev's Avatar
Sev
Originally Posted by Iowa999
No, you don't have to cut the bumpstops.
Yes, you do have to get an alignment.
Old Feb 29, 2012 | 12:58 PM
boostless's Avatar
Why would you NOT cut the bumpstops if you're shortening the stroke by lowering? I cut the bumpstops on my friend's and never had a problem with hitting them...for a reason.
Eibach didn't intend for these to be track or autocross capable; so why make a judgement call based on it?
Old Feb 29, 2012 | 01:37 PM
Iowa999's Avatar
One reason not to cut bumpstops is that a shorter bumpstop is stiffer and sudden, instead of starting soft and being progressive. A cut bumpstop is also - wait for it! - shorter. Therefore, you are much more likely to damage the shock with a cut bumpstop.
Yes, if you're sure that the bumpstop will still do its job when shorter you can cut it and be fine. But if you don't need to cut it and/or are not sure that you'll be fine, it would be silly to cut it.
That's why.
Sev
Oct 2, 2011 05:03 AM
RGRA
Nov 8, 2010 06:46 AM
wrxnevox
Oct 3, 2010 10:44 AM
Snoborder180
Evo X How Tos / Installations
Jun 14, 2009 04:12 PM
JDW1479
Oct 27, 2008 02:11 PM
