Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
285/30/18 issues?
Old Mar 9, 2012 | 02:29 PM
WarmMilk's Avatar
I see the appeal of less weight, but at the end of the day it's the time that matters, and given equal size the Dunlop comes out on top even though it's heavier... (at least in the comparo's I've seen)
Old Mar 25, 2014 | 09:18 AM
Cyp's Avatar
Cyp
Anyone know the weight of 275/35/18 Michelin Pilot SS?
Old Mar 25, 2014 | 09:38 PM
MAX SEAT TIME's Avatar
Originally Posted by EvoX-11
Is anybody running this setup on an X for a while without an issue?
The reason I ask is when I was on the 1010tires' page comparing different sizes, it gave a warning stating:
"When changing tire sizes, we recommend staying within 3% of the diameter/height of the original tire. Any more than this and you face the risk of brake failure."
The difference is %3.82 from stock diameter.
Is this true? Will I have issues with my brakes?
I will be running these tires only at auto x and other events that requires ultimate grip. I will be swapping them with my DD setup once I am done with the events.
If you have clearance in your wheel wells then go for it...I have 3 tire sizes that I use on my EVO MR
285/30/18 BFG R1's on 18x10" D Force rims for Track days Instructing
Going to a 305/35/18 setup this year..
295/35/18 BFG Rivals on 18x10 D Forces for street & wet track
315/30/18 A6 Hoosiers on 18x10.5 Einke's for auto X class SM
No problems with any of them on my car..
Please remember that you need to have proper negative camber to reap the advantage of larger sectional width tires. Use a proper pyro probe to get them right..
I do :-)
HTH,
HAZMAT
StreetThisEvo
Sep 14, 2015 10:59 PM
Corrupter
Mar 6, 2014 02:04 PM
Subi.convert
Oct 27, 2011 04:02 PM
Subi.convert
Jun 19, 2011 02:17 PM
gtr
Sep 6, 2010 06:49 AM
