MR Bilstein shock revalve info
as for adjustments - it was the mentality of "this is the height, spring travel, and spring rate that the Evo X needs" in the GTWorx that attracted me. Doesn't matter how adjustable they are if they're all worse than that one setting
Here is my issue with springs oppose to coils.....
on my second set of GSR (Evo IX) struts because of my swift sport springs.
I have a set of Bilsteins from an MR with 5k miles on them. So if I mount my swift sport springs on my Bilsteins they won't blow out my struts again like my GSR struts?
This is why I'm also considering coils. If I'm wrong please provide me with an explanation?
thanks
thanks
thanks
thanks
More important, to me at least, is that a revalve to new spring-rates will get you the correct ratio of rebound to compression damping. As a spring gets stiffer, you need a higher and higher ratio.
yeah check your PM box buddy. remmember you Pm'd me about my response on the GTworx thread about 4 times. Oh boy.
Did you try the Spec Rs after the GT worx? what are your impressions?
I haven't got to either stage yet. I just got my bilsteins, been trying to decide which springs to get. After reading your review going to get the Swift Spec-Rs. I want to send the bilsteins in and have them revalved specifically for a spring, so I wanted to be sure which ones to get first.
Just gotta find a good deal on some spec-r's now!
- migs
- migs
Originally Posted by trick3d
Well crap if you are going to revalve then i would DEFF get the Spec R's the GT worx are soft.
