Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
max camber on kw v3
Old May 7, 2012 | 10:49 PM
Yogi_B's Avatar
Were the KW front struts inverted?
Old May 8, 2012 | 06:52 AM
Iowa999's Avatar
KW V3s are not inverted. Also, due to their rather unique approach, they have an external canister on the side at the bottom, even though they are twin-tubes.
Old May 8, 2012 | 07:51 AM
jimm's Avatar
Rob's expience not withstanding, I have liked my KWs. Has to be said there is a variety of offerings and the V3s are on the lighter end of the spectrum.
Old May 8, 2012 | 10:50 PM
Yogi_B's Avatar
I'm wondering if that played a part, being non-inverted they would have less bending strength which under rally use (tarmac/gravel) would punish them.
Old May 9, 2012 | 03:40 AM
Robevo RS's Avatar
we did only tarmac, bumpy one , but nothing extra ordenary.
i know they do have a rally spec suspension, but i can not tell you honestly anyone who using them on evo's. We thought we will give a try , since it is a full tarmac, and my co-driver very first event in the rally, we were obviously wrong.
i am sure it will not happened with anyone who doesnt drive crazy fast for long on public roads. I wouldnt use it example for hill climbs and tarmac rally anymore.
Tracks and DD drag racing , autox , they are fine i am sure.
Old Jun 1, 2018 | 02:03 PM
MRKevo's Avatar
Sorry to revive an old thread, but I must ask, did you have any rubbing issues with this setup, and did you have to roll any fenders? Also, were your tires 255/35 or 255/40? A reply would be much appreciated!
Originally Posted by Robevo RS
this was my set up with 255's R888 Toyo tires and the KW V3.
if that is helps. The rims were 9.5 inch and 22+ off set.
the way it looked:
Wilson Chen
11
Dec 29, 2016 06:50 AM
LRM1981
37
Dec 10, 2014 08:37 PM
Anexos
23
Oct 5, 2014 08:04 AM
evo9cuhh
Jun 14, 2014 08:59 AM
Pirana
17
Jan 26, 2014 02:43 PM
