Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
motive power bleeder question
Old May 10, 2012 | 03:34 PM
kneedown's Avatar
Hi, do you guys know which kit I should buy to work on an Evo X?
I guess the ford one should work because it says it will fit late model mitsubishi, but I just wanna make sure.
Thanks.
Old Aug 13, 2012 | 07:35 PM
Showbizz41's Avatar
Thanks.
Im in for some info on this... Been reading about the Motive, but which one has had the best success??
Old Aug 13, 2012 | 07:53 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
If the reservoir is the same as the IX, the ford adapter is what you want. I use one on my car, works like a champ, just remember to keep plenty of fluid in the bottle and keep the clutch side filled to the neck when bleeding the clutch.
Old Aug 13, 2012 | 08:00 PM
Showbizz41's Avatar
Not sure if it is the same... I'll search that..I've read about issues with the Ford adapter though..?
Old Aug 14, 2012 | 07:37 AM
Iowa999's Avatar
Nope. The correct Motive Power Bleeder for an Evo X is model #0107. It's the one for Evos, STis, and 350Zs.
Old Aug 14, 2012 | 09:52 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
No issues here with my adapter.
Amazon Amazon
Old Aug 14, 2012 | 10:09 AM
Iowa999's Avatar
Sorry. The "nope" wasn't aimed at you. The kit you linked to is the 0107, so it's the right one. The key is getting the kit for the small-mouth, three-tab reservoirs and that's the one to which you linked.
Old Aug 14, 2012 | 12:23 PM
armysoldier1073's Avatar
just make sure you lube ring inside cap. it will take a few time to get it to seal right. but once you get it, no issues.
Old Aug 14, 2012 | 12:42 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I usually just rub some brake fluid on it.
Old Aug 14, 2012 | 12:46 PM
^^^^ that what i meant. hope noone "greases" it.
BoostedDaily
Mar 20, 2026 07:55 AM
TxFAkuma
21
Jul 6, 2015 05:46 PM
cmb70
Jun 25, 2015 08:59 AM
05ah8james
Apr 2, 2012 06:52 AM
