will these fit? please help
XXR 527 18x9.75 Flat Black 5-100/5-114.3 [+20mm] will these fit the stock tires sorry for the noob question i wanna get these but i want the 9.75 for an aggressive look thanks guys sorry for the noob question
Whether you have OE-style springs or coilovers does not affect whether the tires will hit the rear fender lips. The rear of an X is multi-link, so the shock & spring play no role in the geometry.
Maybe I should join back in on the whole "your opinion doesn't matter because your name has too many vowels" debate, instead.
You can run those wheels with the stock tires with no rubbing whatsoever, even lowered. I am on Swift springs and ran them for some time and drove the **** out of it. It never rubbed once ANYWHERE. You will be fine. The story changes once you go bigger tire though. The stock 245's are good to go!
edit- Also, when one talks of "rolling fenders" they are talking about the rears only. The fronts are already tight to the body. Rubbing on full lock has nothing to do with the rear fenders.
TxFAkuma
11
Nov 30, 2016 11:16 AM
