Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
SAI/Scrub Radius of the Evo X?
Old Aug 29, 2012 | 08:13 AM
Exyia's Avatar
Been digging deeper into understanding the suspension and tires (yes, the CamberTires, but lets not derail the thread). Focusing on figuring out scrub radius right now.
I understand the concept, but would like to know what the stock values are for reference. Has anyone posted the measurements of these?
Evo VIII/IX section seems to have much better discussion/information on suspension than the X
Old Aug 29, 2012 | 09:08 AM
Iowa999's Avatar
Our SAI is about 13.7* (assuming no camber plate, of course). That seems to match the official value for Evo 7-9s, which was 13.75*.
Scrub depends on offset and I don't know our scrub with the OE (+38) offset, so I can't help you there.
Old Aug 29, 2012 | 09:24 AM
Exyia's Avatar
oh yeah, meant stock, just wanted SAI - rest is easy to calculate as all that changes with offset, plates, etc
thanks a TON though. this section is the only reason I visit evom anymore. back to theorycrafting
Old Aug 29, 2012 | 10:55 AM
Iowa999's Avatar
Note, also, that scrub is slightly altered (increased) when you flip the camber bolts, so it won't be the same same for all Xs running +38 wheels without camber plates. In other words, not all Xs that are obeying the FSM will have the same scrub. This is another reason that there isn't a spec value for scrub.
Old Aug 29, 2012 | 12:40 PM
Exyia's Avatar
FSM?
are you saying its altered in another way besides the fact that it has more camber? because I do understand that more camber at the hub will push the wheel centerline point away from the SAI point (some call it the Dave Point). I was planning on finding stock values, then remodeling with different alignments to see how much it's changing
Old Aug 29, 2012 | 12:55 PM
Iowa999's Avatar
The angle of the steering axis is determined entirely by the end-points of the strut, which are the bushing in the upper shock mount and the ball-joint on the lower LCA. So that doesn't change when you tilt the hub on the knuckle, so where the steering axis hits the ground doesn't move, either. But where the tire hits the ground does move outward when you flip the bolt to get more camber, so the amount of scrub increases when you flip the bolt. Make sense?
Old Aug 29, 2012 | 01:40 PM
Exyia's Avatar
right, we're saying the same thing (aren't we?)
maybe my post was confusing? as far as I know we just repeated after each other
anyway, thought it would be easy to figure out the scrub radius now that I know the SAI, but I'm stumped again...
wheel/tire centerline angle is 89 obviously, and SAI is 13.7 as you said...just lacking any relavant side lengths maybe I need more coffee
Old Aug 31, 2012 | 07:05 AM
Iowa999's Avatar
The missing piece of information is the distance between the steering axis and the hub-face at the height of the axle. You need that, too, to calculate scrub.
Old Aug 31, 2012 | 09:36 AM
Exyia's Avatar
right, and really knowing any of the side lengths would get us there, but being imaginary geometry lines, it's not an easy measure
haven't had time to look at it lately with work, but maybe later
wondering if anyone out there measured this and just hasn't shared
Old Aug 31, 2012 | 10:29 AM
Iowa999's Avatar
There's a bunch of raw data that we should collect in a sticky. Maybe I'll ask a Mod to make a sticky thread for this.
CDrinkH2O
Mar 26, 2018 12:27 PM
EVOlutionary
13
May 2, 2016 08:48 PM
Grendelrt
Jan 6, 2009 07:34 PM
Honni414
Nov 23, 2005 01:32 AM
propellerhead
May 18, 2004 11:13 AM
