Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
swift spec R spring help
Old Nov 25, 2012 | 12:01 PM
suprafabs's Avatar
hey whats up guys, after installing springs came to find out that the guy who installed them did a shyt job, ( left front off by 1/4 inch in height difference front right front and also the rears shocks).
for those who are running this spring with stock gsr shocks, could you please measure the height from bottom fender to a reference point so that i know more or less where i should be at, ( I know every car is different, however just for reference to what more or less i should be )
thanks
Old Nov 25, 2012 | 08:29 PM
RMT-X's Avatar
does it drive fine?
let it settle if its still off in a couple days take it back to him.
Old Nov 26, 2012 | 05:32 PM
suprafabs's Avatar
drives fine, just height is off by 1/4 inch, i have put over 6k on it, so def. settled...
Old Nov 26, 2012 | 07:30 PM
RMT-X's Avatar
yeah i would say so.did you call the installer?
Old Nov 27, 2012 | 05:58 AM
armysoldier1073's Avatar
only thing i can think of is jack car up and see if they are perched correctly. with wheel off the ground you can move the spring, but will take some effort, but can be done if need be.
Old Nov 28, 2012 | 10:59 AM
eug!'s Avatar
I cant imagine what he did wrong, pretty difficult to mess up a spring install. You may want to check your struts and see if he set them into the lower pinches correctly.
Old Dec 1, 2012 | 10:57 AM
suprafabs's Avatar
someone told me also could be the top hats not installed corrected because they are directional?
Old Dec 1, 2012 | 11:42 AM
Chadilac88's Avatar
yes this is true.. there are two holes one on the top hat seat... and one on the lower seat, you want to make sure that the upper and lower seat line up... you can use a rod to make sure they line up
Old Dec 1, 2012 | 07:55 PM
sgtr275's Avatar
odds are that's just how it is. i have never seen a car that sat even. typically one side will sit higher than the other, usually by about 0.25 in.
Old Dec 3, 2012 | 07:08 AM
JRock's Avatar
If that's true, it's typically the driverside that will sit a touch higher when empty, to compensate for the weight of the driver.
Old Dec 3, 2012 | 10:55 AM
sgtr275's Avatar
Not always the case. There was once a theory that jdm cars were biased to account for the driver and that bias was not mirrored for LHD cars, meaning the right side was always higher. My statistical sample (<5000 cars) says there isn't any real correlation.
YCW
Dec 6, 2016 06:23 AM
Metal
Jul 3, 2016 06:29 PM
butters149
Jan 19, 2015 09:07 AM
