Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Speed Bleeder Gone Wrong
Old Dec 28, 2012 | 12:46 PM
Johnr352's Avatar
Originally Posted by shawn360h
my buddy stripped out his calipers from overtightening and then tryed to helicoil them. he was driving it one day and the helicoil came loose and stripped it out further. none the less i wouldn't want to put a tempory fix in something that is so vital as the brakes. I was thinking of a way to almost put a quick coupler for the bleeder screw so when you need to bleed just connect, pump, and your good to go but would have to have someone CAD it up to see if it is feasable.
I suspect that the Helicoil was not installed properly. To do it right you need the special Helicoil kit of taps and such that are relevant to the hole needed M10 x 1.0. Engine builders, which use helicoils regularly, are good sources to fix the caliper, as they have the pieces needed.
While it would be nice to just dash out and buy a new caliper if you strip a bleed screw hole, it's not practical and, really, people should not be afraid of helicoils if installed properly.
Old Dec 28, 2012 | 12:48 PM
Johnr352's Avatar
This is the type of solution I'm thinking about but it wouldn't fit our brakes without some fussing.
http://www.summitracing.com/parts/aaf-all50180
Kainvorador
Feb 4, 2018 09:12 AM
Djstorm100
68
Dec 28, 2015 08:44 PM
spyghost
Lancer How Tos / Installations
Aug 8, 2013 11:00 AM
CDeutsch
34
Aug 25, 2006 12:31 PM
