long wheel stud install - rear
If you've looked into or actually swapped wheel studs, then you know that the fronts are easy and the rears are a total pain in the ... er, rear. If you get the 3" ARPs (#100-7717), you have to remove the rear hub to do the job. But I don't need studs that long. In fact, an extra 14mm would be quite sufficient.
example: http://www.racingbrake.com/EVO-03-07...k-p/evo-57.htm
So, here's the question: does anyone know if you can swap in studs this length without removing the rear hubs?
I can't verify. I didn't do the rears, EFI Logics did it and only indicated that it required pulling the hub. They did not indicate whether they could swing it out of the way. I believe they did just swing them because I don't recall needing new cotter pins for the axle nuts.
tim85851
Jan 16, 2026 08:11 AM
ryukinevo
17
Aug 11, 2014 07:51 PM
free ride
37
Mar 31, 2014 01:21 AM
llDemonll
Jun 8, 2012 04:21 AM
vtluu
Jul 24, 2005 08:33 PM
