help front wheels
OK, so now you have burned a hole through the shock or just made a pretty dot, depending on strength of said laser.
OK, so now you have a string wrapped around your spring.
I'm still not getting this. And I've mapped a car's suspension before.
I guess you could put the car on jackstands, remove the entire front suspension, draw the dot on the ground, re-install the suspension, and measure where the knuckle is relative to the dot.
But I'm thinking there are easier ways to do this that don't involve a dot on the ground.
tee hee
tee hee
tee hee
tee hee
Funny guy
Originally Posted by Cellar Door
Open the hood and draw a virtual line from the center of the shocktower(its cap) straights down to the ground. Now measure the distance from the center of the wheel to that line (so they meet at 90 degrees).
I don't feel like drawing but if you compare both left and right this will give you an answer. Also you were asked if the car is pulling to one side or driving weird.
Posted from Evolutionm.net App for Android
http://www.automedia.com/Content/Art...640&height=410
Or option 2 - probbly best for the op
http://www.virginmedia.com/images/me...sh-431x300.jpg
dannyz
15
May 18, 2014 09:57 PM
samm928
10
Nov 12, 2011 10:21 AM
aaj the man
13
Mar 28, 2003 02:23 PM
