Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Brakes squeaking bad!
Old Apr 6, 2013 | 05:59 AM
Redusn's Avatar
Squeaky new Brembo brakes????
My car is very new with only about 900 miles on it and since day one my brakes are very squeaky, is this normal for Brembo Brakes???
Old Apr 6, 2013 | 07:31 AM
Buru_EvoX's Avatar
yup. especially when its cold outside
Old Apr 6, 2013 | 08:35 AM
Iowa999's Avatar
How many of you with noisy OE Brembos have put anti-squeal on the shims?
Old Apr 6, 2013 | 10:12 AM
►EvolutionX◄'s Avatar
If your talking about brake grease, it will make the noise go away, temporarily; until it gets washed/worn away. I re-grease mine whenever they start making the noise and it does fix the problem for a little while.
Buy some brake and caliper grease, apply it to any part of the brake pad backing plate that will be touching any part of the caliper or piston or brake hardware.
Old Apr 6, 2013 | 10:16 AM
Evoxgsxr1k's Avatar
I have the same problem with mine. I think it is pretty common. Usually I take it on a back road and dust them off with a hard break from 100 or 80 mph down to 10 or so. Makes them wear more than normal when doing this but hell, thats what they are there for right? It does make the brake noise go away for a long while though for me.
Plus, it lets you see just how hard they clamp down incase you really did need them for an emergency.
Old Apr 6, 2013 | 10:27 AM
Iowa999's Avatar
No, I was talking about anti-squeal, such as CRC red, not grease.
Old Apr 6, 2013 | 05:23 PM
lippy1306's Avatar
Have the same issue. It's the worst when the brakes are cold. It's a common issue from what I've heard.
Old Apr 7, 2013 | 06:54 AM
titleistforged's Avatar
Mine's still squeaking, 4000 miles later. Will consider new pads - heard that it'll "fix" it.
Old Apr 7, 2013 | 08:15 AM
Redusn's Avatar
I haven't tried any anti squeak stuff yet cause I've heard mix reviews on that, yesterday I tried "bedding" them from 80 down to about 10 mph and that helped for about a day, it's only really doing it when coming to a stop at a red light or parking
Old Apr 7, 2013 | 09:09 AM
Iowa999's Avatar
Originally Posted by Redusn
I haven't tried any anti squeak stuff yet cause I've heard mix reviews on that.
If you have brakes with shims between the pads and pistons, what are the downsides of anti-squeal that you've heard of?
Old Apr 9, 2013 | 12:48 PM
r34p3rex's Avatar
High performance brake pads tend to do this
Old Apr 9, 2013 | 02:02 PM
ufcgsp27's Avatar
i have same issue as well. its so embarrassing and i was told its normal for these brakes....
Old Apr 10, 2013 | 11:41 AM
USMC Evo's Avatar
*My apologies, I just realized theres a thread on this right below my post, oops* [FIXED]
The brakes on my Evo are making a godawful squeak in low speed braking. It sounds like its mainly from the front ones, pretty much only happens at 20mph and under. It seems to happen more often when its cold. Its been doing for a while now, started not long after I bought it.
Dealership told me it was because they were new. I've been gone for the last 11 months nothing has changed. I've been by a brake shop (said they couldn't find anything wrong with them) and the new Mitsu dealership here also looked at them, said "I don't know why they do it, I think its because they're racing brakes." They said there was nothing wrong with them.
Is this just how they are or am I, and they missing something?
Old Apr 10, 2013 | 12:42 PM
en1gma's Avatar
the infamous Brembo Squeak.
Unfortunately it will always be there and it is hard to get rid of.
But it is caused by the harmonic vibrations between the metal moving parts in the caliper itself.
What I do to remedy it, every 3 months or so or when the squeaking starts to get bad, re-lubricate all the metal to metal parts with some copper grease or Synthetic brake grease.
Rob.
Old Apr 10, 2013 | 01:48 PM
Redusn's Avatar
appreciate it guys, this week it hasn't done it nearly as much and i'm sure its because the temps here are now in the mid 80s.
