Bilstein PSS10
Bilstein PSS10
Does anybody have feedback about the Bilstein PSS10 coilovers on the EVO X? I see them listed on TireRack but haven't really found reviews on them on the EVO X.
I saw a webpage of someone who installed it in Japan... buy unfortunately that entire webpage was in Japanese.
If they're just the next version of the PSS9, then I wouldn't be too hopeful. Why Bilstein even makes a shock with a single bleed adjuster is beyond me. But, then again, I still don't get why Porsche makes an SUV.
Yeah, my post comes across rather badly, because it doesn't include my default feelings about Bilsteins. What I meant, especially when you note the parallel to Porsches, is that these aren't up to Bilstein's usual standards, assuming that they are like PSS9s. The PSS9s aren't much better than OE MR Bilsteins and the adjuster affects rebound and bump at the same time, so they aren't really "tunable," either. I'd go higher, if you have the money. I'm not hopeful that these will good entry-level coilover.
PSS10's use a completely different adjuster than the older PSS9s (that a lot of people complained about).
Still a 1 way with rebound and compression together, but a lot more predictable. I haven't been able to try them and haven't seen any dynos yet though.
- Andrew
- Andrew
Glad to hear (and not surprised) that Bilstein responded to the complaints about PSS9s. Everyone should ignore all that wrote above with regard to the PSS10s.
The money Porsche makes selling sedans and SUV's they can use to develop the 911 Turbos, GT2s, GT3s and 918's that we all love. And yeah.. I'm not gonna ride on the "cheap Chinese junk"!
Almost nothing. The OE Billies from an MR are some of the best OE shocks on any car made.
As you know from reading the thread before adding four replies, my comments against PSS10s were based on the false assumption that they were a tweaked version of PSS9s. The latter I don't like because the ratio of rebound to bump is too low; the adjuster affects both at once, so this cannot be fixed; and the adjuster was inconsistent from one shock to the next and highly non-linear. You pretty much had to have PSS9s revalved before using them, at least for a 2G DSM.
