Rs05rr help
Subscribe
Apr 15, 2014 | 07:01 AM
I just recently purchased the rs05rr. I was wondering what tire size I should get without having to roll the fenders on stock suspension. The wheel size is 18x9.5+22.
Thank you
Reply 0
Apr 15, 2014 | 10:53 AM
265/35 all day on a 9.5".
Reply 0
Apr 16, 2014 | 10:37 AM
Quote: 265/35 all day on a 9.5".
So with the monster truck height on the Evo X, a 9.5 rim with a low offset such a +22 or +25 won't rub inside the fenders?
Reply 0
Apr 16, 2014 | 10:40 AM
Quote: So with the monster truck height on the Evo X, a 9.5 rim with a low offset such a +22 or +25 won't rub inside the fenders?
Stock height, I'm not sure. But when you lower it, it will most def. rub the front liner. Easy fix though, just heat it up and mold it so it won't rub. Or just keep driving it that way until it makes it's own hole.
Reply 0
Apr 17, 2014 | 09:15 PM
+25 definitely doesn't rub, had 9.5, +25 last year, no problems.
10, +22 on my car with 265/35, the tire is flush with the fender and the wheel is out a bit.
I rub on big dips and bumps. I'm ok on 99% of street driving. Stock monster truck suspension.
I also have to use a 3mm spacer in the front. Doesn't clear the brake caliper.
Reply 0
Apr 18, 2014 | 07:41 AM
Quote: +25 definitely doesn't rub, had 9.5, +25 last year, no problems.
This also depends on spoke design.
Reply 0
Apr 18, 2014 | 08:16 AM
Quote: I just recently purchased the rs05rr. I was wondering what tire size I should get without having to roll the fenders on stock suspension. The wheel size is 18x9.5+22.
Thank you
This depends if u r dropped or not. I have the Swift Sports with 18x9.5 +24 no issues. Very close when turning steering wheel all the way.
Reply 0
Apr 18, 2014 | 08:19 AM
Just noticed OP is stock height. NO you will not rub. I am dropped and no rubbing
Reply 0
Apr 18, 2014 | 09:13 AM
Quote: This also depends on spoke design.
I meant for my 10", +22, RS05RR.
I'd like to know if the 9.5 and the 10.5 versions clear, as they have a different face design than mine.
Reply 0
Apr 18, 2014 | 09:42 AM
Ohhhh, got it.
Reply 0
Apr 18, 2014 | 01:29 PM
Thanks for the advice...I will find out tonight or tomorrow after installing them
Reply 0
Apr 18, 2014 | 09:26 PM
Quote: Thanks for the advice...I will find out tonight or tomorrow after installing them
Cool. Keep us informed.
Reply 0
Subscribe
