Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
suspension stiffening
Old May 7, 2014 | 03:13 PM
evoxbrampton's Avatar
Hi all I am looking for a way if there is any to stiffen my rear suspension I have 3 12s in the truck, I would say they are about 50 pounds each. I notice that my rear is lower then my front just wondering if there is any way to fix that without changing my suspension?
Old May 7, 2014 | 05:51 PM
incogSuperhero's Avatar
No. You are unable to stiffen your current suspension without changing your current suspension.
This is because you are unable to alter the spring constant because that characteristic is fixed for each spring.
Old May 8, 2014 | 03:41 AM
OK so do you have any recommendations for another suspension I could use that's stronger?
Old May 8, 2014 | 06:30 AM
Iowa999's Avatar
Actually, you can stiffen coil springs by adding rubber gizmos. If the OP googles "spring stiffeners" he or she will see the options. Not that I'd do this to my car, but, then again, I'm not the sort to have three subwoofers in my trunk, so what I'd do is irrelevant.
Old May 8, 2014 | 06:52 PM
Johnr352's Avatar
I suppose I wouldn't add the rubber gizmos. How heavy can 3 12" subwoofers be? I think it is something else. Granted we run 12k springs in the rear, but even with ballast the rear doesn't move even a smidge.
Old May 8, 2014 | 07:16 PM
jimm's Avatar
You are better than me, I didn't know what the "3 12s in the trunk" was referring to.
Old May 9, 2014 | 06:38 AM
Iowa999's Avatar
Well, I'm not very young, so maybe I'm wrong about what the three 12" things are, but my memory is that the magnets on some sub-woofers are very heavy and I couldn't think of any other explanation for the first post.
ps. a good way to ensure that the files that you downloaded onto the computer owned by whomever you work for are no longer there when you bring the computer back to the office from home is to put the CPU on top of a mondo subwoofer magnet; not that I have ever had any need for this
Old May 9, 2014 | 07:11 AM
CrusifiX's Avatar
I pictured this, minus the 1911 in his trunk when he said 3 12's.
Old May 9, 2014 | 08:19 AM
Nagua's Avatar
Back in the day when I was a young whippersnapper I had one badass woofer. 12" that weighed by itself no box 55 lbs. so this member with box and woofers is probably carrying around an xtra 200-225 lbs.
Old May 9, 2014 | 10:21 AM
Iowa999's Avatar
Well, to be honest, when I see the word "hoops" (even if in someone's name) I immediately think of giant white rabbits with guns, so that all works out.
ps. if any of you get the reference to which I'm alluding, then all I can say is "old school D&D rocks!" and then boast that I once DM'd Gary Gygax
Old May 9, 2014 | 11:28 AM
CrusifiX's Avatar
Love the part with the lobsters in the pool.. yeah, that is a great movie.
Old May 9, 2014 | 12:08 PM
Iowa999's Avatar
Wow. I have absolutely no clue as to what you're referring.
Old May 9, 2014 | 02:16 PM
dek0026's Avatar
Came in for info. Left after reading a bunch of nerdy ****.
Old May 9, 2014 | 02:38 PM
CrusifiX's Avatar
Sorry. Thought you were referring to the movie, One Crazy Summer.
Old May 12, 2014 | 07:39 AM
Sephiron's Avatar
I would like to know what to do as well. I only have 1 15in so maybe about 75lbs extra in the trunk and I also notice that the back is lower in the back on stock suspension. I will be getting swift springs in the next month or two.
Specifications
Front Drop: 1.25"
Rear Drop: 1.0"
So I hope that it does a little leveling.
