Alignment Specs
I would Zero the rear toe, and bump the camber up to 2.3-2.5 in the front. Or buy adjustable rear camber arms and run less rear camber. Having camber so close front to rear causes the rear to end up with too much grip (relative to the front), and the car pushes.
I am running about -2.5 front and -1.5 rear. Amazingly it didn't wear my AD08's as fast as I thought it would. They did end up showing metal on the inside edge but they lasted awhile. Plus I got lazy and hardly rotated them and didn't flip them on the rim.
I run -3.1f on my Evo 10, works great for a heavy car. I went from -1.7r to -2.0r and it made a large difference in grip and stability on the track with my current setup.
Of course, every setup and driving method takes a slightly different take on alignment but honestly, like I said above, -2.5r / -1.5r is basically just a "good start" for an Evo.
With zero toe all around, tire wear is just fine. I ran -3.2f on my Evo 8 for years as daily/track use. I even ran it like that in the snow.
testa corse
Aug 14, 2011 02:04 AM
iodine23
15
Apr 16, 2003 10:01 PM
