Control arm advice
Control arm advice
Going to be ordering the Ohlins R/T's here next week and wanted to order a set of adjustable lower control arms from Whiteline but they are on backorder. So my question is, should i wait for the Whiteline quality or is there something else with the same quality??What i don't want to do it is buy a set and regret it 2-3 months down the road when i should of just waited for the whitelines to start with. I know there are a few out there just don't know the quality of them...
Torque Solution..
Megan Racing..
Agency Power..
K27 from Kozmic Racing..
Timmy Spec..
Thanks in advance guys
Torque Solution..
Megan Racing..
Agency Power..
Timmy Spec..
Been doing some more research and reading the Whitelines have 100mm's of adjustment and some of the others like Megan Racing are like 0-2deg's adjustment for mostly stock replacement and look's
Need some
if anyone knows about the other products listed above ..
Ohlins R/T's will be on order soon, just trying to get more info on the adjustable control arms so i can order them at the same time.
Thanks guys
Need some
if anyone knows about the other products listed above ..Ohlins R/T's will be on order soon, just trying to get more info on the adjustable control arms so i can order them at the same time.
Thanks guys
I would wait for Whiteline as well. I have some Megan Racing rear lower adjustable control arms and I had to shave down the ends because they were too thick for the frame.
They are working with no problems though. Able to achieve the alignment I wanted, also did some autocross with those installed.
don't waste your time with whiteline. Get literally any brand. It doesn't matter. Chet Rickerman was making some arms at one point in time for pretty cheap, like 200 or 250 ish. Talk to him.
RunThat
23
Mar 29, 2011 09:48 AM
4cdndctn
Feb 11, 2011 09:21 AM
Solo II Evo
Jan 10, 2011 01:45 PM
Pr3z
Jul 17, 2008 02:17 PM
