Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Roll center adjustment
Old Jul 11, 2016 | 10:06 AM
ol_buck's Avatar
So if I buy lowering springs or coilovers how serious is it that I purchase the white line roll center adjustment kit?
Old Jul 11, 2016 | 10:49 AM
RazorLab's Avatar
For street use, don't waste your money. Just don't slam the car.
Old Jul 11, 2016 | 10:55 AM
ol_buck's Avatar
I don't plan on it! I just want some Spec-r lowering springs or some street coilovers so that its lower with a higher spring rate. I was just not sure if the roll center kit was completely necessary
Old Jul 11, 2016 | 11:09 AM
evostanman's Avatar
huh... everyone swears that I need it because I lowered my evo on springs. How it messed with the car's center balance thingy... hmmm?!
I'm not slammed because, well, I'm not stupid
Old Jul 11, 2016 | 11:17 AM
ol_buck's Avatar
That's what I had read, that it realigns the suspension geometry since the car has been lowered. I mean if we need them I'd buy them but if not then I would prefer to save $250
Old Jul 11, 2016 | 11:33 AM
LetsGetThisDone's Avatar
If you're going to autocross and going for the fast time of the day, or trying to eek every last bit out of the at a track day, it's pointless. You won't notice it just cruising on the street or hitting your local twisty roads..
Old Jul 11, 2016 | 01:48 PM
RazorLab's Avatar
For sure don't need it with Spec-R springs.
The forums swears about a lot of things. Lots of noise.
Old Jul 12, 2016 | 08:03 AM
ol_buck's Avatar
[QUOTE=razorlab;11639101]For sure don't need it with Spec-R springs.
Why do you say for sure with those springs? do they not lower it enough to affect the suspension geometry in a bad way?
Old Jul 12, 2016 | 08:43 AM
sujinX's Avatar
swifts barely lower the car at all. most consider them as the "weakest" drop.
Old Jul 12, 2016 | 08:45 AM
ol_buck's Avatar
maperformance.com says 1.25 inch drop in the front and 1.0 in the rear for the Swift spec-r springs
Old Jul 12, 2016 | 11:51 AM
RazorLab's Avatar
Here is my 10 when it was running Swifts on OEM bilstein struts:
Compared to when it was 100% stock:
Old Jul 12, 2016 | 11:54 AM
ol_buck's Avatar
Looks like a good height. Would you recommend a different brand of spring? And I'm guessing you went to a coilovers setup?
Old Jul 12, 2016 | 11:59 AM
RazorLab's Avatar
The progression of suspension on my 10:
Oem --> Bilstein + Swift Spec R --> Apexi ExV 8k/8k Coilovers --> Ohlins 10k/10k Coilovers
Old Jul 12, 2016 | 12:30 PM
ol_buck's Avatar
Alright well I guess when I do springs I won't get the roll center adjustment kit, but when I eventually do coilovers I'll buy it
Old Jul 13, 2016 | 10:49 AM
evostanman's Avatar
Would you recommend Apexi coils for a DD evo (maybe 3-4 track days a year)?
houckeah
13
Jul 7, 2009 04:13 PM
evo8silver
May 15, 2009 03:13 PM
EVO8LTW
15
Jun 20, 2007 07:02 AM
Jamie@WORKS
Evo 'For Sale' Suspension / Brakes / Handling
Jan 13, 2007 12:50 PM
