Sure, the offset can be adjusted by adding wheel spacers. The stock X wheels are the following: 18x8.5 +38 offset, Center Bore 67.1
Search the forum as this has been done many times. You will have to decide, based on tire size & rear fender fit, whether to run a 10mm,15mm or 20mm spacer
Thanks for the info.
I thought that i might need spacers but unfortunately I just found out recently that wheel spacers are illegal here in Australia
Yeah, we try to play by the rules but i live in the states, specifically Calif which is one of most **** states in this fine union
I have had to break the rules on many occasions to enjoy this car hobby. Spacers are a mod that really cant be seen & unless you were in an accident where the spacer was involved unlikely anyone would ever know
If you can believe it, Australia is WAYYYYYY more strict than California.
I know it's not something that will be noticed so I'm considering doing it but like you said if I ever get into an accident it might get noticed then and I worry about my insurance companies not covering me.
