Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Preload on Coilover
Old Apr 21, 2020 | 06:41 PM
ak47m203's Avatar
Preload on Coilover
On street use do we need a preload, zero load. How much normally,4mm???. I know it is set by the factory I just want to check it if it too much.
Old Apr 22, 2020 | 04:24 AM
macca916's Avatar
From my experience of coil overs on other cars the answer is very dependant on the spring rate and spring length & the shocks expected spring platform adjustment range, desired ride height (if set by spring platform and not shock length). So how long is a piece of string in effect .
ultraflip
Mar 31, 2017 12:03 PM
henryncoke
Dec 1, 2015 04:58 PM
Olynth
Mar 3, 2008 08:22 AM
smokedmustang
17
Dec 10, 2005 06:53 PM
