Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Spacers needed
Old Mar 22, 2021 | 11:53 AM
jd8888jd's Avatar
5 Year Member
Spacers needed
Hello,
Not sure if this thread has been covered or answered.
Whats the biggest size spacers you can put on our evo 10 without extending the lugs, and still safe.
Thanks
Old Mar 22, 2021 | 01:04 PM
Pretty sure any spacer 5mm & beyond should need the extended studs. Years ago i installed H&R 5mm spacers & they came w/the extended studs
Some exacting details here:
The allowances and tolerances specified in the standard assume normal lengths of engagement between male and female threads. The definition of ‘‘normal’’ is spelled out in the specifications, but, typically, it means lengths of engagement ranging from 1.0 to 1.5 times the nominal diameter of the thread. Lengths for fine-pitch threads are alternately given in number of pitches, with a range of 5 to15 being considered normal.
butters149
Feb 4, 2014 08:54 PM
kpt6
For Sale - Wheels / Tires
11
Jun 5, 2013 04:15 PM
kpt6
Jun 5, 2013 04:14 PM
