Question about Clunk Noise.
Old Sep 21, 2006 | 10:06 AM
evo72man's Avatar
Every time I start the car and I shift to reverse I hear a clunk noise before it engages. I turn off the car and then shift into 1st gear or second gear, there isn't that much of a noise. Is this standard? I have own DSM before and this doesn't seem standard, but this is the first time I have owned a EVO. Sounds like the clunk is coming from the drive shaft or the transmission.
comments appreciated.
Old Sep 21, 2006 | 10:22 AM
smoothmarine187's Avatar
Veteran: Marine Corp
Sometimes it will stick if you try to go into reverse right away, I usually shift into first....bump it forward a little and then shift into reverse.
Old Sep 21, 2006 | 11:15 PM
dreaminevo's Avatar
i might be the parking brake ! i use to have a car that did that . it would clunck when i started moving . it was just the praking brake hanging up a little bit then harshly releasing
weiyan8
Sep 18, 2012 10:38 AM
BoostedAWD91
12
Jun 29, 2012 11:49 AM
HR2L
Mitsubishi TC-SST Discussion
17
Oct 5, 2009 11:22 PM
mitchedout
Jan 21, 2009 09:10 PM
Ultor
May 21, 2004 09:06 AM
