problem with boost leak test
Old Sep 27, 2006 | 06:10 AM
vennom's Avatar
I am having a problem doing a boost leak test. The problem I have is with my hks evc. When i put pressure into the cold side of the piping, There is a small hole in a black electronic evc box that i believe controls the wastegate.
Anyways when I add pressure the box leaks and I cant add enough air to hear any leaks.
Would taping the hole work or would I run the risk of breaking something?
Any answers are greatly appreciated.
AJ
Old Sep 27, 2006 | 08:43 AM
vennom's Avatar
ttt
Old Sep 27, 2006 | 11:43 AM
vennom's Avatar
nobody? I have a stalling problem when I come to a stop and I believe that it might be because of a boost leak somewhere between the intake and the intake manifold.
Thanks
AJ
Old Sep 27, 2006 | 11:45 AM
Evoryder's Avatar
do you have a bov?
Old Sep 27, 2006 | 12:20 PM
vennom's Avatar
yes I have a jdm evo 9 bov
Old Sep 27, 2006 | 12:28 PM
Evoryder's Avatar
what are the symptoms...give me a scenario
Old Sep 27, 2006 | 12:37 PM
kimletrim's Avatar
Registered User
u should be able to block off the hole with your finger
Old Sep 27, 2006 | 08:17 PM
vennom's Avatar
when driving and comming up to say a stop sign the car will bog to ~200/300 rpms the oil pressure will drop very low and sometimes the car will die because of the symptoms. It didnt happen when I had the forge bov, but then again it was installed on backwards (bought it that way). Switched to the jdm going the right way and it starts dying. I havnt tried the forge installed in the correct direction.
Old Sep 28, 2006 | 05:27 AM
Evoryder's Avatar
i had a car that had the same symptoms...it was actually caused by a dirty throttle body...my rpms would bounce low "bounce bounce"...i'd have to rev it to keep it from dying...cleaned the throttle body and this fixed it...
don't think your bov is the prob. you don't have any SES lights? ...log the car anyways
Old Sep 28, 2006 | 09:38 AM
vennom's Avatar
No ses lights to speak of, I do have a bunch of oil in the intake though
Old Sep 28, 2006 | 09:43 AM
GinuwineEvo8's Avatar
Is your MAF Cable loose? Make sure its plugged in correctly and tight ..
Old Sep 28, 2006 | 09:44 AM
Evoryder's Avatar
oil in the intake is somewhat usual...blow back...might wanna invest in a oil catch can once you get this issue fixed. Hows the power ? ANy loss in power? Clean your maf sensor w/ CRC electrical parts cleaner
also can u bypass the boost controller...just to do the test again...plug the lines into each other...and try to make sure you have the same boost level you normally boost at eg 21psi...don't flood the system with 27, 30psi or whatever....
Old Sep 28, 2006 | 02:52 PM
vennom's Avatar
thanks man ill try that
Old Sep 28, 2006 | 03:09 PM
vennom's Avatar
newcomer81
Apr 1, 2010 07:35 AM
freakitgood
Mar 19, 2009 12:13 AM
PorkRoll
23
Oct 18, 2007 01:33 PM
MitsuJoe
Nov 19, 2006 04:21 PM
bracer
Apr 4, 2005 08:33 PM
