Huge boost leak!
Old Oct 17, 2007 | 11:10 AM
PorkRoll's Avatar
Huge boost leak!
I am pressure testing my car for leaks...well either im doing something wrong or i have a major leak that is not visable. The car will no hold even a pound of pressure. The air is comming out as soon as it goes in it seens like. What would cause this? There are no visable holes or leaks anywhere. I smoke tested it with low pressure there is nothing wrong from what i can see. Im still seeing 21-22 psi like normal. The boost tester is fuctioning properly so that is no the cause. Anyone chime in with whatever ideas they have.
Old Oct 17, 2007 | 11:31 AM
PorkRoll's Avatar
Anyone?
Old Oct 17, 2007 | 11:37 AM
WagsEvo's Avatar
What are you using to pressurize the system? You need a compressor that can deliver enough psi to offset the small leaks that add up to one big leak.
If you are trying a bicycle pump, it won't work (personal experience).
Old Oct 17, 2007 | 11:43 AM
milo's Avatar
Where should you start to pressurize the system?
Old Oct 17, 2007 | 11:46 AM
TeStUdO's Avatar
http://www.vfaq.com/mods/ICtester.html
Take off the intake, and start at the turbo.
Old Oct 17, 2007 | 11:53 AM
milo's Avatar
Thanks for the info
Old Oct 17, 2007 | 12:03 PM
PorkRoll's Avatar
Im using an 80 gallon compessor. The exact max psi im not sure but 90-100 i would guess. The tester im using is a rubber pipe conector with a flat end cap on it. I used a tire valve to get air into it.
Old Oct 17, 2007 | 02:09 PM
jrsimon27's Avatar
when i tested my system i had very big boost leak it didnt allow me to build boost max boost i saw was 8psi just hear where it is i had to put my compressor a 120galon compresor far away so i could hear my boost leaks when i inmediatly fix the leaks the boost gauge went easy fast up tp 23psi.
here are some pics as how i did it:
i did not take out the maf pipe i left it where it was
Old Oct 17, 2007 | 03:00 PM
Erik@MIL.SPEC's Avatar
Check to see if the EGR vacuum hose is connected on your throttle body. That would cause all your air to leak out during the boost leak test. Don't ask me how I know
Old Oct 17, 2007 | 03:09 PM
mplspilot's Avatar
Either you unplugged some vacuum hose, or if you have mbc, you did not plug the turbo hose that goes to it (usually on the bottom).
Old Oct 17, 2007 | 03:23 PM
PorkRoll's Avatar
i have a mbc and the hoses are on. The egr valve is ok. all i can build the pressure to is 5 psi. the exhaust is plugged the oil fill cap is off and no air is comming out of there. i still dont hear the leak nut it obviouslt there some where. this is so fustrating.
Old Oct 17, 2007 | 03:26 PM
SOEuro's Avatar
check ur BOV
Old Oct 17, 2007 | 03:27 PM
precisi0n's Avatar
did you turn your motor to TDC?
Old Oct 17, 2007 | 03:45 PM
PorkRoll's Avatar
bov is ok. no tdc....how do i know when i have it at tdc.i know i have to turn the crank but when do i know when the piston has reached the top?
Old Oct 17, 2007 | 03:58 PM
precisi0n's Avatar
there are lines in the cam gears and the valve cover... turn the motor(crank in passenger front wheel well) until these marks are lined up
