i need help asap please
Old Sep 27, 2006 | 12:11 PM
JeffMas1587's Avatar
ok so i got the buschur/wt package and went to start installing it today. first i did the fuel pump. i followed the directions on evomoto.com and everything went smoothly. i started the car and it held idle and every thing was fine. i didnt drive the car but i reved it up, every thing normal. next was the new forge bov. i took out my greddy one and installed the forge one the exact same way. pretty straight forward. 2 hoses and a vac line. dont think i messed that one up. next was the boost gauge. i already had a boost gauge on my turbo timer but i like haveing an actual gauge that is big and easy to see. so i just cut the line that went from my old boost gauge and sliped it over the line that came with my new boost gauge. and i zip tied it to make sure it has a good connection. i blew in the line and got boost and vac so the gauge is working. after all this is installed i went to turn the car on. it started up ok held idle for 5 seconds and then started to die. so i give it some gas and the rpms just continue to drop. car stalls. i do this a few more times but the car wont hold idle. it will just die even if i try to give it gas. i dont know where i went wrong. can anyone help me out?
Old Sep 27, 2006 | 12:15 PM
gsrboi80's Avatar
Go back over everything agian you have a leak dude
Old Sep 27, 2006 | 12:16 PM
WrX Kila's Avatar
Hmm.. I would go over everything again. Make sure that you did not unplug something by mistake.
Old Sep 27, 2006 | 12:17 PM
idriveanevo's Avatar
how much boost and vac did you produce? jk. whats the vac reading wile its trying to idle?
like a vac leak or a fuel leak. i will go back and check every thing again. ahh this is frustrating
Old Sep 27, 2006 | 12:22 PM
gsrboi80's Avatar
its a vac leak man check all your connections dude
Old Sep 27, 2006 | 02:32 PM
Danny23's Avatar
definetely sounds like a leak somewhere,i would check the bov first and go from there.
