Oil changes question
Old Oct 7, 2006 | 09:26 AM
03SilvaEvo's Avatar
So rule of thumb is to change oil every 3k miles. Out of curiousity there anyone out there that likes to change their oil earlier than 3k? For me I like to do 2500 miles.
Old Oct 7, 2006 | 09:50 AM
BuLocal's Avatar
35,000 miles and I've never gone more than 2500 miles between oil changes.
Old Oct 7, 2006 | 09:52 AM
x838nwy's Avatar
well, you could change it everyday if you want. really depends on what oil and the application of the engine i'd say...
Old Oct 7, 2006 | 10:00 AM
WickedIXMR's Avatar
dont ever change it. Itll make your car faster in the long run trust me.
Old Oct 7, 2006 | 10:03 AM
epearson's Avatar
rofl
fully synthetic oil is actually typically good for 5k-6k miles but it also depends on mods and how you drive the car. if you're not at the track often and such you're fine changing it every 4k-5k.
DruMMinStUd06's Avatar
changing the oil too soon is just as bad as not changing it enough. imo changing it every 2500 is unnecessary and could cause harm unless you drive the car very rough/track it often. if you're driving normally (occasional boosting) you can do it at 4k or maybe even 5k if you wanna push it.
Old Oct 7, 2006 | 10:05 AM
WickedIXMR's Avatar
dude man im telling you just wait like a 100k miles then change it and if it comes out all clumpy and has some silverish stuff in it, that just means your car is running as strong as can be.
Old Oct 7, 2006 | 10:14 AM
x838nwy's Avatar
how can changing it too often be bad? (except for financially, obviously)
Old Oct 7, 2006 | 10:15 AM
Kayaalp's Avatar
The big issues with our engine oil are: (1) the same oil also cools the turbo; (2) the volume of oil is quite low; and (3) the oil filter is tiny.
We have just 4 quarts of oil trying to lubricate, clean, and cool both a high-rpm engine and a white hot turbo...with an oil filter that's barely big enough for a lawn mower.
You need to be pretty **** about checking your oil levels and topping up as necessary. Even if you don't plan to change your oil every 3K miles, you'll probably want to change the filter. Changing the filter is already a messy job. As long as you're getting oil all over yourself, it's easy enough to go ahead and drain the oil pan at the same time. I suspect that's why most of us flush the whole system every 3K miles even though we could probably get away with just swapping filters.
Emre
Old Oct 7, 2006 | 10:19 AM
sparky's Avatar
I do mine at 2500 mi. intervals, using Mobil1 and a fresh filter. If you wanna go 4000-5500 mi., then, if it was me, I'd at least change the filter at the 2500 mi. mark, and top it off with fresh oil. Just my $00.02. My reasoning being that perhaps the oil is still good but if the filter has been doing its job it may be loaded with particulate matter.
Old Oct 7, 2006 | 10:22 AM
x838nwy's Avatar
I'm gonna try that. Will let you know in a couple of years time.
Anyway, saw this programme on TV. Basically, they were trying to show how indestructible Honda Cub's (those tiny old school scooters) are. They bought one like 20 years old, the owner didn't know it need oil change ever. Rode it around a bit then drained all the oil out the replaced it with used cooking oil from a restaurant. Started first time. The engine ran. Actually sounded better.
Then they threw it off a 4 storey building. It landed, bent both wheels. But stated second time. That's better than some evo I know of....
Old Oct 7, 2006 | 10:39 AM
gsrboi80's Avatar
3k in every car i ever owned
Old Oct 7, 2006 | 10:50 AM
EVOL EDO's Avatar
every 3k in my mustang tried doing it before 3k in my viii, but i think i went to 3100 once i have 1900 on my ix and am going to change my oil for the first time soon
Old Oct 7, 2006 | 10:55 AM
gsrboi80's Avatar
^ British horse power roflmao
Old Oct 7, 2006 | 11:01 AM
DanJ's Avatar
I typically do it every 3k, i don't think I went over. However it's easier to remember to change it ever 2500 miles
because it would be something like this: 10,000 12,500 15,000 17,500 20,000 It's all nice and even.
