View Poll Results: Fuel pump needed?
Yes
41
100.00%
No
0%
Voters: 41. You may not vote on this poll
When is a fuel pump needed?
Old Jan 16, 2007 | 10:10 AM
grenade's Avatar
I've got an 05 Mr, with the following mods, and Im wondering if I should do a fuel pump now
Comp 280 cams
MBC @ 25psi
Coated/Ported o2
Muegen Header
3in DP/No Cat/3in custom exhaust
ARP head studs
Cone Filter
TurboXS BPV
Innovate LC-1 Wideband
Ecuflash/Evoscan/Mistulogger
Im thinking that I do need a fuel pump right about now, and am going to go with a 255lph.
Anyone think I do too? Thanks
Old Jan 16, 2007 | 10:11 AM
bvdawg13's Avatar
you should get one now
Old Jan 16, 2007 | 10:12 AM
03silevo's Avatar
yeah you are probably starting to run lean if you dont have one by now with a mbc set to 25 .....i mean what kinda of afrs are you running right now with all them mods and no fuel pump thats scary
Old Jan 16, 2007 | 10:13 AM
ak47po's Avatar
Should of had a fuel pump long ago.
Old Jan 16, 2007 | 10:17 AM
KEVO8's Avatar
For sure....you should have up-graded your fuel pump when you added the MBC.
Old Jan 16, 2007 | 10:22 AM
Bigl4201's Avatar
Originally Posted by saiyanzzrage
kill yourself
WTF is wrong with you. Thats your response to anything. Are you suicidal ?
Old Jan 16, 2007 | 10:26 AM
KartaRailed's Avatar
Fuel pump was nessacary at like the full exhaust and MBC, why the hell is your boost so high anyway? I hope I missed where you stated you had meth injection or always run race gas.
Old Jan 16, 2007 | 10:30 AM
03silevo's Avatar
be prepared to be flamed and i hope a shop off of here didnt do your work for ya
Old Jan 16, 2007 | 10:34 AM
Jewish Santa's Avatar
why hasn't the shop that does you're work recommend you getting one?
Old Jan 16, 2007 | 10:36 AM
tweakdsm's Avatar
Yes.
Old Jan 16, 2007 | 10:41 AM
TxEvo8's Avatar
I agree, that is way too high for pump gas! Yes your FP should have gone on at the same time as the MBC, do you have a boost gauge? WOW...
I think you need to spend a lot of time reading these forums, you are heading for disaster..
Old Jan 16, 2007 | 10:46 AM
LVIIIR's Avatar
yeah you are way over do for one!
PA-silver03evo's Avatar
Both the flash and the mbc require fuel pump upgrade. Especially on an VIII. Get one asap.
Old Jan 16, 2007 | 10:52 AM
EVIL_EVO_VIII's Avatar
Get it asap.. I have less mods than you and when TTP was tunning my car a while back, the stock fp wasnt able to keep up.. You WILL need to retune after the fp as your car will run richer like it happened to me
Old Jan 16, 2007 | 10:55 AM
hondafan's Avatar
mbc shouldn't even be in without a pump, let alone all the other mods.
