Air intake Question
Old Feb 6, 2007 | 02:14 PM
Dark-Knight's Avatar
Air intake Question
Will the K&N typhoon intake system work on a EVO IX? I saw it on evomoto.com, but it showed it was for the EVO III. Both the EVO III and IX look identical to me under the hood. Does anyone have this intake already on a IX? Please give me your feed back. Thanks
Old Feb 6, 2007 | 02:30 PM
EVOBrad's Avatar
That's just about the worst intake you could install. Stick with the factory intake and do a simple drop-in filter.
Old Feb 6, 2007 | 02:36 PM
2Devious's Avatar
No, the K&N will NOT work is the best answer.
https://www.evolutionm.net/forums/sh...=k%26n+typhoon
Like mentioned above, just go with a drop-in (for minor future mods) or a proven intake setup (for major future mods) + a tune.
Old Feb 6, 2007 | 02:45 PM
GraphanaticIXSE's Avatar
Just go with the drop-in... The stock intake system on the IX is fine. The drop in is all that you will need. Spend the rest of your time and efforts and other mods...
Old Feb 6, 2007 | 02:57 PM
Boltz.'s Avatar
FCOTM Winner
Just buy an open element filter and use it with the stock rubber MAF pipe. The aftermarket MAF pipes cause intakes to run poorly.
Look into AMS ($60) or Apexi (~120)
Old Feb 6, 2007 | 04:57 PM
srtfourplay's Avatar
there a lot of talk on these forums about intakes! damn mitsubishi should just used a map sensor on the manifold and it would make things so much easier! my srt-4 was set up that way and i could use what ever intake i wanted!.. i miss that. but any ways question.
my car is flashed for the hks RS intake. currently the stocker is on it tho. i want to keep the airbox for the sound purposes and just use a drop in. am i looking at possible power loss keeping it this way?the intake was removed befor i bought the car but i still flashed for it. and 400 bucks is a lot of money. suggestions??
Old Feb 6, 2007 | 05:10 PM
the1andonlyE's Avatar
The box will muffle your sound. You should use the intake pipe and get you an add on filter, the sound will be much louder
Old Feb 6, 2007 | 05:17 PM
Warrtalon's Avatar
Originally Posted by Phenix_fyah
his name is Warrt for short
Warr, damnit!
Very bad idea to be flashed for an intake but not have one - fix that immediately even if you just get a $50 e-flash.
Dark-Knight, yes the Typhoon will fit, but if you're even looking at that intake, then you haven't done any research on here whatsoever. We should probably just let you spend your $200+ and mess up your Evo, but we're not that mean. Don't touch that intake...
Old Feb 9, 2007 | 08:09 PM
jvans04's Avatar
drop in k&n filter with the adapter is the best bang for the buck in my opinion
Old Feb 9, 2007 | 09:55 PM
nashmage's Avatar
other then a drop in what are the intakes people recommend?
Old Feb 9, 2007 | 10:20 PM
Rox's Avatar
Rox
Socks...
Anythings better than a tube sock!!!
Old Feb 9, 2007 | 11:38 PM
ddubdb3's Avatar
can just a cone filter without a tune be used?? or is it just all bad
Old Feb 10, 2007 | 12:29 AM
ultimatesteve's Avatar
Considering that it wont flow much better then the stock intake with a drop in filter I dont think it would pose much of a proble, but chances are your not going to gain anything from it.
Old Feb 10, 2007 | 12:32 AM
srt2evo9's Avatar
i had an Apexi filter kit on my car (filter + MAF adaptor) pulled it off and put the stock box in w/ a stock filter and couldnt tell a difference either way
Old Feb 10, 2007 | 03:18 PM
dogfacker's Avatar
HKS RS is what i have, and it work perfect
