"High Flow Cat" question.
Old Feb 8, 2007 | 10:53 AM
Chemwarrior's Avatar
Originally Posted by EVO8emUp
Damn talk about waiting until the time is right.
Well, at least we know you're not a tease!
I hope it at least bought you dinner!
I know where someone's mind is at!
Old Feb 8, 2007 | 05:36 PM
Dr.Sound's Avatar
oh u dont know man! i'll blow anything if it gives me more power
Old Feb 8, 2007 | 06:12 PM
Robevo RS's Avatar
i have vibrant performance. when i put the test pipe on, after the HFC.i only gained 7hp.
but i don't know with that HFC you will pass the emission test.i never tryed to do it.
Old Feb 8, 2007 | 06:41 PM
nothere's Avatar
the vibrant comes ready to install?
Old Feb 8, 2007 | 06:51 PM
Dave2's Avatar
Originally Posted by evo150
ultimate racing high flow cat......not sure how close it is to stock for smog
i have the ultimate racing HFC for 1 year, the first few month it works great. afterward, my car smell like it doesn't have cat.
Old Feb 8, 2007 | 07:35 PM
kouzman's Avatar
have the same one. however i am not happy with the power steal as at my mod level the restriction is higher. I am not sure about using a testpipe thought...probably after easter i will get a high end metalic catalytic converter... (randomtech, sard, etc etc)
Old Feb 8, 2007 | 08:04 PM
ispeedtoo's Avatar
I have the Buschur and the cat works great. The slip fit is fine unless you plan to pull the exhaust often. I have a question about cpevo setup. What type of ECU are you runiing? Is it a stock ECU with flash?
I am going to Dyno in the next week for a reflash I have stage 1-4 plus the 20G-9LT. First Flash AFR was way off we got it figured out now. Tell me about your setup?
Old Feb 9, 2007 | 04:25 AM
Robevo RS's Avatar
no. you have to add the the thing on both side...
Old Feb 9, 2007 | 11:50 AM
my-red-rs's Avatar
Originally Posted by guam
What are some of the HFC that are close to stock as far as smog/legality?.....I'd appreciate the feedback!....thanks,
Regarding being legal, it goes somthing like this... "If the vehicle is more than eight years old or has more than 80,000 miles, and a legitimate need for replacement has been established and documented. ""
See the following for more details
http://www.car-sound.com/04basics/04epa.asp
Old Feb 9, 2007 | 05:18 PM
Ludikraut's Avatar
IIRC, an aftermarket CAT is only legal in CA and then only if it has a CARB number. All other states require that the stock cat is replaced with another OEM cat.
l8r)
Old Feb 9, 2007 | 05:33 PM
Lil red '03's Avatar
Subscribed
Looking forward to seeing how this turns out
Old Feb 9, 2007 | 05:36 PM
Vigo's Avatar
In California you can only replace the stock cat with an aftermarket one if your stock cat is not fully functional anymore. Like what Ludikraut said it would also need a CARB number. IIRC the fine for not running a cat would be $15,000 to $20,000. If you replace the stock cat to a high-flow-cat while the stock cat is still working properly you will probably get the same fine.
Old Feb 9, 2007 | 05:51 PM
Vigo's Avatar
Originally Posted by cpoevo
I passed the smog test here in CA with a 3" hi flow cat 272cams and 780 injectors. So the cat must be doing something good.
How did go about in doing this in Cali? Was your stock cat not working anymore?
Old Feb 13, 2007 | 07:49 PM
cpoevo's Avatar
My car is registered in TX and I have to pass the CA emission test because of the Navy. I dont have to pass the visual test. I think my cat is from Magnaflow. I had a shop make it and I dont know for sure what the brand is.
As for replacing it before the 8 yrs 80,000 miles my factory cat got damaged and needed to be replaced.
Old Feb 13, 2007 | 08:05 PM
Vigo's Avatar
Ohhh, I see.
