Intermittent rough idle... kind of like a "hiccup"
Old Mar 12, 2007 | 07:29 PM
Mr. Evo IX's Avatar
Your car is probably fine as is mine, and the dealership is probably right in this case. I actually had 3000 miles of constant P0300 misfire codes which were attributed to a faulty injector (all 4 were replaced, P0300 gone). This was when I changed plugs, wires, compression tested, boost leak tested, de-carboned, fuel injector cleaned, swapped coils, looked for exhaust leaks, and tested o2 sensors, and anything else I could think of. Car still idles rough, always has - I'm guessing its normal and the car was always making good power and never had a noticeable high rpm misfire like when your plugs are gapped too wide (popping). The CEL would just come on (especially in the rain with the wipers and defroster fan on). On a OBDII logger you could see the fuel trims getting out of whack and then the light would come on, the idle would get rougher until you reset the ECU and then it would run normal until the trims got out of whack again.
Old Mar 12, 2007 | 07:49 PM
amstel78's Avatar
Ahh.. interesting. So your car idles pretty much the same way I described mine?
BTW, do you have a code reader, or did you have to go to a shop with an OBDII scanner?
Old Mar 12, 2007 | 07:54 PM
JRB_EVO's Avatar
Your car is okay, '06 EVO's have a lumpy idle, that sounds sounds as if it had a cam, like someone pointed out here earlier. Mine has been like that since day 1, it now has almost 7200 miles and it ran 13.1 bone stock, stop worrying man, just drive it and enjoy it!!!
Cheers!
Old Mar 12, 2007 | 08:28 PM
amstel78's Avatar
Cheers!
Thank you for your reply! It certainly helps to put my mind at ease. Anyway, I just bought an OBD-II reader from Amazon just in case... I'm sure I'll need one sooner or later.
Old Aug 23, 2010 | 04:29 PM
tinto1's Avatar
Have the same problem in my 08 evo x, but it only happens sometimes. It drives fine and pulls strong, it's just at idle , and it pisses my off sometime, but i can't figure it out. The car has a catback , maybe that's the problem.
Old Nov 2, 2010 | 06:43 PM
rally305's Avatar
Hey I know these threads are pretty old but yeah the lumpy idle on the evo 9 is pretty much how its described here, my evo 9 has 88,600 miles and yeah it idles exactly how you guys have described. It still pulls very hard and idles at 900 rpm, everything normal. I even checked vaccum readings and its normal at around 19 hg thank god
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
GeoMitsu
Dec 27, 2015 02:41 AM
Smithta
Oct 1, 2015 03:41 PM
princess33
Sep 14, 2014 08:08 AM
millsyy17
Jan 13, 2010 07:11 PM
