Stiffest/hardest front motor mount insert?..
Old May 22, 2007 | 07:52 AM
MR Dan's Avatar
Im currently running the Powerflex front motor mount insert but looking for something stiffer. Any other brand thats stiffer/harder? Inserts only please....
Old May 22, 2007 | 07:59 AM
Jdav79's Avatar
I think the AMS mount is a 90 Durameter. The AGP is very stiff too, however I don't know the durameter rating of it. There is also the AVID mounts, however they come in 60/75/90 so if you wanted the stiff you would need to get the 90.
Buschur also sells a front one but I am not sure of the stiffness....
Old May 22, 2007 | 08:09 AM
MR Dan's Avatar
koo thanks...I guess no one makes anything stiffer than 90 durameter
Old May 22, 2007 | 08:13 AM
Jdav79's Avatar
I think it comes down to the fact that if you go too stiff you are just bound to break something. I mean there has to be a little give somewhere.
You could always just make some pieces out of metal and weld them in, but the welds would eventually just break.... Besides if they were any stiffer they would rattle your teeth right out of your head....
Old May 22, 2007 | 08:25 AM
fugiwara's Avatar
+1 to Jdav79
powerflex insert are rated at 80 durometer, this is perfect balance for street and track use. I have 2 powerflex motor mount and 1 tranny mount, and they works great. you should do the same too if you don't have the them yet. b/c by just replacing the front one w/ the hardest it's not gonna do you any good if you dont have the side ones upgraded.
Old May 22, 2007 | 08:35 AM
MR Dan's Avatar
ok since I already have the front Power Flex inserts, would doing the rear be equivalent to swapping out the side mounts? either I get mounts for the rear or just the sides?
Old May 22, 2007 | 08:38 AM
Jdav79's Avatar
I would do the passenger side and the Transmission mount before you do the rear one. First of all getting to the rear mount is about impossible unless you have the tranny out (While doing a clutch). It is something that most likely you will have to have a shop do.
The two side mounts are relatively easy so long as you have access to a press and a stud puller. (The stud puller for the transmission mount so you don't have to lower the tranny by 3-4 inches, much easier).
Old May 22, 2007 | 10:09 AM
evo150's Avatar
i would keep the front power flex and get both side powerflex mm
Old May 22, 2007 | 10:40 AM
MR Dan's Avatar
now the question is who sells the side powerflex mounts here?
Old May 23, 2007 | 07:21 AM
evo150's Avatar
lancershop.com here is a link http://www.lancershop.com/customer/p...&cat=90&page=1
morellana
Sep 16, 2014 08:05 PM
nesty2
May 29, 2014 04:10 PM
Shaun@AWDMotorsports
Oct 15, 2013 08:50 AM
Vivid Racing
EvoX 'For Sale' External Engine / Power
Aug 30, 2012 04:33 PM
Vivid Racing
35
Mar 4, 2006 07:57 PM
