Spark plug help?
I have 17k miles on my Evo. I pulled 2 plugs which are iridium plugs to see how worn they are. Looks like they need replacing. I should be putting down around 330 to the wheels. My question is is it time for a colder plug? If so can someone give me the part number for the NGK plugs?
7s are stock heat range. 8s are one step cooler.
http://lancershop.com/customer/produ...7&cat=0&page=1
you should go one step colder for every 100 hp over stock. so for your application you are probably better off with the ngk bpr7es or the half step colder br7es.
there is no specific formula to how much additonal horsepower you should running over stock to install colder plugs. some say after additional 100 hp or like speed corps says 75hp. it depends on your specific car, mods, gas, boost, tune, etc. when you do start making 75-100hp over stock it may be time to go a half step to a full step colder in plugs.
I think Im just going to go with a half step colder. Does NGK make iridium plugs that are a half step colder then my original iridium plugs? It looks like it only goes a full step colder.
binh
Dec 11, 2009 07:52 PM
silverstream
Nov 10, 2009 05:01 PM
