I NEED HELp some one please answer me
Old Jan 29, 2008 | 12:57 PM
jackchn152's Avatar
hey guys... i recently let my car run out of gas and the next thing u know my car won't start up anymore.... i filled it up with more gas... and it still won't start.. i dunno wat it possibly could be.... could some help tell me what is wrong with it..... or any suggestion .. could hlep thanks
jc white evo
Old Jan 29, 2008 | 01:09 PM
SilverShadow03's Avatar
I had this happen in another fuel injected car....did you turn the car to the 'on' position without cranking it (after filling it up with gas again) and let it sit there for a minute to let the fuel pump fill the line? That worked for me after a few cranks it was fine. What year evo? You could have sucked in some crap from the bottom of your tank by letting it run out....
Old Jan 29, 2008 | 01:12 PM
dsmjeffro's Avatar
Burned Out Fuel Pump Happen To Me In My Supra Same Style Pump See If Its Priming Or Get A Walboro You Need It Ne Way & If You Alrady Have It Try Your Stocker Back In There
Old Jan 29, 2008 | 08:37 PM
Jameson_IXMR's Avatar
The fuel pump gets really HOT when theres no fuel. Likely you burned the pump up. I would tap a 12 volt source and ground and see if the pump does anything. You should be okay sitting it in some water to see if its working.
Old Jan 29, 2008 | 08:46 PM
ciclops04's Avatar
+11 i burned my fuel pump from my 02 chevy pick u/p same thing ran out of gas, well at least you have an excuse to upgrade to a walboro.GL
Old Jan 29, 2008 | 08:54 PM
CDO's Avatar
CDO
Maybe you sucked water out of the bottom of your tank and it froze in your line. Get a bottle of isopropyl alcohol (HEAT, etc.) and see if that gets it going.
Old Jan 29, 2008 | 10:24 PM
gixxerman11's Avatar
burned +1
Old Jan 30, 2008 | 06:47 PM
MikePL's Avatar
This sounds kinda like what just happen to me..before you think the worst ..like a burnt fuel pump...My car ran out of gas and got cranked (not by me) and it would not start even with more gas...took out the spark plugs..cleaned them...and boom started right up...maybe it will work for u...no harm in trying..really easy to do..
Old Jan 30, 2008 | 06:50 PM
Curt@MrLed's Avatar
Former Vendor
check the pump fuse.
mistergomez316
Jul 1, 2012 10:03 PM
evo unknown
Aug 30, 2009 05:34 PM
evane
12
Dec 15, 2008 07:44 PM
dafoe69
14
Mar 14, 2007 09:57 PM
Forbiden
AEM EMS
20
Dec 22, 2004 10:40 PM
