question bout CAI
Old Aug 9, 2003 | 11:22 AM
kuruption's Avatar
question bout CAI
I just got a lil question bout tha CAI's. Im hearing that they are only for 5 speeds and if that is true, why is that? holla bac. peace
Old Aug 9, 2003 | 11:36 AM
digdat's Avatar
Automatic transmissions are big and take up the room in which the CAI piping would run. Hence they generally only fit on manuals, unless ya wanna get custom piping.
Old Aug 9, 2003 | 05:31 PM
kuruption's Avatar
damn, is that all? aiight
Old Aug 9, 2003 | 06:24 PM
J'sLancerLS's Avatar
You could also move the battery to the trunk to make room for custom piping for a CAI. I almost did that, but went with RRM SRI and installed custom ram air using 3" insulated ducting.
Old Aug 9, 2003 | 06:42 PM
Smoktout's Avatar
it's not the battery that's in the way.....it's the size of the automatic tranny is too big to fit the piping down under the battery.
Old Aug 9, 2003 | 06:45 PM
Trust me, there's room if the battery is moved. Boe and I were gonna make something, but I got too lazy to move the battery, and also figured out the ram air ducting... much easier!
Old Aug 10, 2003 | 03:49 AM
WADADLIG_OZ's Avatar
J'sLancer why does your RRM intake sit at an angle like that different to the other pictures that I have seen? Did you do something to it?
WADAD
Old Aug 10, 2003 | 10:35 AM
Cool
I bought a 3" to 3" 90 degree rubber elbow from Home Depot along with new hose clamps. It's basically the same thing that the Injen SRI has. Had to cut the elbow back so the MAS would sit the way you see in the picture. It's less restrictive than the OEM rubber elbow... smoother and larger inside diameter lets air flow through easier to the throttle body. That's also why you see the small breather element attached to the valve cover, eventually I'll attach a fitting to my "custom elbow" to allow me to reconnect the hose that would normally run from the valve cover to the OEM elbow. Can't pass smog without that hose being connected.
