Some advice on HP
Old May 13, 2009 | 08:54 AM
Yamahar1's Avatar
Some advice on HP
I have a 04 with the following mods:
Buschur double pumper
BC 272 cams
ETS HTA35r turbo kit w/44mm wg
Injen air intake
bigger intercooler
3" TBE
1000cc injectors
stock 9 BOV
ACT 6puck sprung clutch
gates racing timing belt
E-85 ----English racing tune
stock block
stock ecu
Ingalls engine damper
BLOX Racing Front Engine Roll Stopper
Greddy catch can
29lbs of boost
What would I need to do to see 400-500 HP?
Old May 13, 2009 | 08:58 AM
PVD04's Avatar
A decent tune.
Old May 13, 2009 | 09:11 AM
heel2toe's Avatar
You look like you have yourself quite the list. Your BC 272's may be leaving some power on the table as shown from the ams cam test. Assuming you have a good tune you should be there no problem.
Old May 13, 2009 | 09:22 AM
Yamahar1's Avatar
I'm thinking about getting the Kelford 272 cams..just not anytime soon. maybe this winter
Old May 13, 2009 | 12:22 PM
RockmanX's Avatar
you should be there now with that mod list just get you a good tune and done
Old May 13, 2009 | 12:26 PM
TxEvo8's Avatar
says he has a tune, you are probably over 500 whp
Old May 13, 2009 | 12:32 PM
CAD EVO's Avatar
How does the car feel to you?
Does it feel slow as compared to other cars you have had?
That thing should be moving on E-85, Assuming you have an English racing tune you should have a good tune already and the numbers you listed.
Old May 13, 2009 | 02:27 PM
Yamahar1's Avatar
well the car feels GREAT!!!! Thanks to Aaron! but me and a buddy of mine raced and he was right behind me. We just had his car dyno and the best the guys could get was 277 hp.
His is also a 04
Mods are..........
gt35r turbo kit w/megan manifold
HKS bov
injen air intake
1200cc injectors
93 octane
stock ecu
stock block
walbro 255
272 cams
19 lbs of boost
Old May 13, 2009 | 02:38 PM
cornercarver's Avatar
I would say that he made good power......on 19psi. If he bumped it up to 29psi like you he would be up there in the high 300's on a mustang dyno on 93oct.
You should be at 400-500whp with that setup. However, your 1000cc injectors may be maxing out with the e85. You may need to get 1200-1400's.
Old May 13, 2009 | 02:52 PM
Yamahar1's Avatar
now that you say that....I think Aaron told me that I needed 1200cc
Old May 16, 2009 | 01:22 AM
MULLDOG's Avatar
35r? Yea man, get a good tune. turn up the PSI and im betting you will have no problem seeing 500+
One thing with the E85 tho. Dont know to much about e85 but im pretty sure you are going to want some bigger injectors (maybe atleas 1200's?)
Old May 18, 2009 | 06:00 AM
SoflaEvo9's Avatar
Dont mean to go off topic, but if your thinking of switching cams the JUNs are sex.
Old May 19, 2009 | 07:13 AM
evolution45's Avatar
Im shocked u havent cracked 500 already! Its an HTA 35r! its definately the tune dude.
dave12285
Evo X Dyno Results
14
Nov 25, 2012 01:53 PM
Oettinger
19
Aug 19, 2012 11:22 AM
racemc
Jul 10, 2010 07:57 AM
MrEvo2nv
15
Dec 3, 2008 01:01 PM
javis06ralliart
23
Aug 24, 2007 09:04 AM
