i need stock brembo rear torque specs please!
Old May 22, 2009 | 03:58 PM
IAmADirtDude's Avatar
i have searched somehow i got the from caliper torque as 85 but not sure if the rear is the same.... i started and it felt like it might be too much so i want to make sure the caliper torque for the 2 bolts on the rear is 85ft lbs
thanks a[ppreciate it
Old May 22, 2009 | 04:04 PM
o7'silvermax's Avatar
you dont need no exact torque spec on that...ive done plenty of caliper swaps on 240's and used the impact gun and never had a problem
Old May 22, 2009 | 04:55 PM
Loser's Avatar
For the IX:
Front brake assembly mounting bolt 108 ± 10 N⋅m (80 ± 7 ft-lb)
Rear brake assembly mounting bolt 54 ± 5 N⋅m (40 ± 4 ft-lb)
Old May 22, 2009 | 05:03 PM
twabtoxer's Avatar
haha i did mine at the tq at the fronts oh well , now i know theyre not going anywhere
Old May 22, 2009 | 05:08 PM
Protostar1's Avatar
You do realize the calipers are aluminum, you can strip a hole more easily on these than some other calipers... Also, over torquing can lead to over stressing components and possibly cracking something like a bolt, there is a reason for torque specs.
Old May 22, 2009 | 05:15 PM
ya over tightening and impact gun is ignorant on something aluminum and definatly on a saftey item like brakes. i'm a cat mechanic and i know from experience theres certain things/ most things you do by torque of your arm and hand but things like this need a torque spec thanks for the specs
Old Oct 23, 2010 | 06:41 PM
4wd4me's Avatar
I did the same and destroyed my rear caliper... gotta have it rethreaded/sleeved
stupid mistake, learn from my misfortune.
Old Nov 27, 2010 | 11:47 AM
rockchucker's Avatar
Proper Torque Spec on any Bolt is a must. Sure they will hold after you blast them in with an Impact but it weakens the Bolt actually causing a possible unsafe condition where the Bolt is allowed to stretch, fatigue and break.
You should do some research on the effects of over Torquing Bolts.
http://www.engineersedge.com/torque.htm
http://www.engineersedge.com/fastener_thread_menu.shtml
http://www.engineersedge.com/calcula...orque_calc.htm
Kind of nifty...
http://www.engineersedge.com/calcula...conversion.htm
gigitalon
Apr 2, 2017 03:29 PM
Stig013
Dec 28, 2015 05:58 AM
Tobra
Jul 25, 2015 06:50 AM
Matt_Jagg7
Apr 10, 2009 07:17 AM
